Wesley,I am simple thinking !
https://www.youtube.com/watch?v=NPAx_jNQLPM                                 https://www.youtube.com/watch?v=R2jaY5VQMTg
1280x720 Pixel bei 50 pictures pro Sekunde                                            3840x2160  Pixel bei 50 pictures pro Sekunde
signal-to-signal  image-/and sound repeat quality transmission experiments ? 1-4% losts efficiency in quantity/quality !?
"...or ..." was related K. Masaki his description ,f.e.  :
The magnetic field lines generated when an electron flow having the same phase of voltage and current flows through the coil also penetrates a metal plate or seawater.
Eindringtiefe ? Funny (but not only,some " or" cases more)
https://translate.google.com/translate?sl=de&tl=en&u=https://www.thm.de/mni/forschung/institute-gruppen/imps/imps-strahlung-information/strahlenschutz/einwirkung-und-durchdringung-von-strahlung.html
material viskosity : Debye,Engeler and other physical units
Sincere
OCWL
p.s.: it is also the question about "service quality and warranty",
        defined f.e. in Germany by law
        https://translate.google.com/translate?sl=de&tl=en&u=https://de.wikipedia.org/wiki/%25C3%259Cbermittlungsirrtum
        free translator we have to see " at your own risk, legal recourse is excluded " ,but will/wants Viziv work for free ?
stivep
Quote from: lancaIV on June 05, 2021, 01:16:58 PM
https://www.youtube.com/watch?v=NPAx_jNQLPM               =https://www.youtube.com/watch?v=R2jaY5VQMTg
Very nice example.
I can  use it to  adjust my cameras to the  max focus.
But   that is only one of the factors.
Key Differences
The 4k image is smoother, and has more detail than the 1080p image.
Edges around objects in the 1080p picture are noticeably more serrated. ...
4k content is still quite rare, most of what you watch will probably be lower-resolution satisfied up scaled to
UHD, which will look different from native 4k and 1080p.
certain resolutions can only be seen on specific displays that are large enough to make a difference.
- if your monitor isn't big enough to show a difference between the two, paying the extra cost may not be worth
the benefit of buying 4K.
My motion  picture cameras are  :
4K,    Sony Ax-100                          fdrax100
5.7k   EVA-1              Film camera    https://youtu.be/CppZpVfgCE8       hphoto
6K     BMPCC6k Pro.   Film camera    https://www.youtube.com/watch?v=ltMBvp2ENM0
when rendering the original higher resolution e.g 6K
into the  4k  resolution - the picture is always better  than that from any original 4K  Camera
_______________________________________
Explanation of the above:
what is Film camera in 2021?
it doesn't use film and chemicals.
It is called  Film camera but it is digital.
A film camera often has a higher resolution than what is found in most
digital cameras used  for documentary or  photographic work.
Well this is not always true.
Film Camera is  the Cinema Camera and no any other type of camera  is allowed by Netflix
or Hollywood.
Film Camera  has  in mind  almost manual operation and definitively
no continuous auto focus. It's as if we take  a power  of Ferrari
and manual transmission, manual brakes, manual light control, and manual fuel pump, manual speed control
but you'll never need to pay any tickets.
So survival is not guarantied.
The beauty  of it is that if you are  average  driver you simply can't drive  such car
you must be an artist and professional.
and that is why  Film Camera can't be used as a - "run and gun"
Explanation:
"Run and gun"- is a term used to describe a style of filmmaking with very little production equipment
besides a camera. Run and gun is typically used in documentary-style filmmaking, as filmmakers aren't
always given the luxury of a controlled set.
Wesley
stivep
___________________________________________________
Few rules that never changes:
1. overunity  doesn't exist.
2.  perpetual motion machine  is impossible to be made,  but  everything  else is more close or more  far to perpetual motion .
a.-   practicality any  machine   close or far  to  perpetual motion is important  just from the  perspective of its application.
3.   only original natural energy  is for free, everything else  must be paid for.
     That means  every conversion to the  form  of energy  we prefer .. cost money.
      but it may be one time cost only  plus some  periodic maintenance .
a.-   "closeness"  to Perpetual Motion  is measured by efficiency  efficiency is a measurable concept, quantitatively determined by the ratio of useful output to total useful input.
example:
efficiency  of  gasoline engine 40%
efficiency  of solar panels are roughly between 15% and 18%
efficiency of Niagara falls waterfall 60 to 75%
efficiency of  energy Extraction  from Schumann waveguide  is not important
as we don't pay for any  of  its  Energy at any point of conversion.
From perspective of economics
Perpetual Motion  is  when - $1  in  your hand  taken out from your left  pocket and  than placed into  right pocket still reminds   unchanged
In physics :
the cost of energy  used   to  move $1 from left to right pocket using  your  hands  is coming from food you consumed .  And if someone  else  paid for that food than you'll have perpetual motion but only from your point of observation.
Evaluation  of devices of any  of the  presenters.
question they must answer:
-if it works than show me  extra energy  compensating losses
-If you can't show or explain   to me the origin of  extra energy  than we have two  possible options:
1- the device is  using additional energy  that is paid by nature but we just don't see it yet  with:
-our   measurement devices
-and we don't  understand the mechanism  of that particular energy conversion yet.
2- the device is fake  among 99% of other fakes.
Wesley
