0 Members and 157 Guests are viewing this topic.
Void
Quote from: PolaczekCebulaczek on July 26, 2018, 12:20:34 PM
Sergej said that he found a spot to connect mains and then the device worked, with all tesla coils pushpuls, fans, leds and so on, those parts are just a decoy. Sergej did not modify anything , supposedly.
He also had shown all schematics and explained how mains current powered the device including relay's for battery.
Hi PolaczekCebulaczek. 'Supposedly' being the key word there. :)
I saw in Sergej's video where it looked like he actually had soldered his thin phase wire
in more than one place, but I don't speak Russian so I am not sure about what Sergej was
trying to show there.  Anyway, the same circuit layout may work exactly the same if the
power source is looping back from the output of the coils in self loop configuration, or if a mains hot phase
wire is soldered in the same place instead (prior to the loop back diode bridge). I'm personally not jumping to
any conclusions here anyway. :)
PolaczekCebulaczek
QuoteHi PolaczekCebulaczek. 'Supposedly' being the key word there. :)
that would be a surprise, hwoever one thing just makes me wonder, why in forest demo ruslan insert a pipe in some bushy area instead of open field?
Wesley is trying to contact Ruslan, Wes would bring HIS OWN ground wire or choose a location for demo, he will inspect everything, no room for hoax this time, if Ruslan let him...
Void
Quote from: PolaczekCebulaczek on July 26, 2018, 12:49:00 PM
Hi PolaczekCebulaczek . Yes, I agree, it would be essential for Wesley to be allowed to disconnect the ground wire
at least at the end of the ground wire which connects to the device and inspect fully, and also to be allowed to handle
the device however he wants to inspect the device for any possible hidden wires as well. Doing the demo at some
random location in the country side, with the exact spot chosen by Wesley would be very good as well.
However, I can pretty much guarantee you that no matter what precautions and steps Wesley may take,
such as the steps mentioned above, (if Ruslan agrees to something like this), and if the device still works,
people will still be insisting that Wesley was still just tricked somehow, or they will insist that Wesley has joined
up with Ruslan to fool everyone. ;D
apecore
Quote from: onepower on July 26, 2018, 12:04:40 PM
Void
There is a very good reason these devices work in some places some of the time but not all of the time. Relative humidity, water in the air, will either dampen the HV resonant effects or short the device out all together. It is well known in the art and anyone with any amount of understanding of these kinds of systems should have figured this out.
A nearby thunderstorm produces even more variation because now the Earth Ground potential can swing from 100V/m to thousands of V/m overloading the device. Then when the wind blows humid air into the vicinity the unit shorts out and stops working all together. Why anyone would think a device extracting energy from it's environment would not be effected by said environment boggles the mind.
Imagine that, some people put hundreds of hours of testing into a device and it never works for no other reason than they didn't check the relative humidity in the room. It is often something that simple that many people over look that gets them.
It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so. Mark Twain
Well it makes sense.
This means that the device needs to have a supply of condioned air?
Should not be that difficult.
Also the ionisation charge of the air trough the during thunderstorm should be relative easy to be controlled
Quote from: Void on July 26, 2018, 01:24:36 PM
And that would be the correct default position to take. Extraordinary claims need extraordinary levels of proof, after all. And what claim is more extraordinary than these: Self runners, not co-opted by the Russian military....
However, what is much more likely is that Wesley will not be allowed to perform the necessary inspections and experimentation to rule out hidden external or internal sources of power.
A third possibility is that the device won't work, and Ruslan and his cadre will fall back on the "onepower" excuse: not enough something in the air, too much other somethings, not Tuesday, not full enough moon, forgot to circle three times widdershins around the plinth....
