0 Members and 23 Guests are viewing this topic.
stivep
important  to understand  is that  Zenneck wave doesn't radiate in air. Communication is NOT DONE IN AIR. THIS WAVE DOESN'T EXIST IN AIR.
At Near field  from UP/Down tuned Top capacitor    wave enters INTERFACE  at Complex Brewster Angle and exists only  in that interface from now.
in TM mode .
It needs to be understood that winding the particular Tesla Coil according to posted by  me (first picture of my post from above.)
1. 2200m = 136,24 khz takes 30 minutes. (using lathe) or 3 hours  if  pivoted  and  all winding information is  in the picture.
                                                               pivoted manual winding : at best takes 2 people
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg562296/#msg562296
2. this coil is good for short distance testing of A to B energy transfer as mandatory learning curve experience  before  EEfSW.
3. the minimum equipment that is needed for that is:
a-  for Tx 3 pieces  or  just 1 generator,  look at second picture  from previous  post and Tesla Coil.
b-  for Rx exactly the same way winded Tesla coil and the load look at second picture  from previous post.
Person walking the distance of 200m between  Tx and Rx  with LED testing probe in his hand starting his walk
from the Tx can see light on LED in Near Field than LED quickly light dims  in Freshnel zone and disappears.
At the Tesla coil  Rx (receiver site)  it doesn't work that way.  The power is seen only at the connected to it load.
At both  the Tx and Rx  impedance match and complex Brewster Angle  tuning is a must!!! It will not work without it.
tuning  was explained here and in two of my dedicated  to it topics.start to read from here :
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg546325/#msg546325
practical schematic of Tx at 2200m= 136,24 khz is here:
https://overunity.com/18335/wireless-energy-transfer-experiments-builders-board/msg547756/#msg547756
in Russian: https://overunity.com/18913/in-russian-ekspierimienty-po-biesprovodnoi-pieriedachie-enierghii-doska-stroitieliei/msg559483/#msg559483
перейти на все 5 страниц
Wesley
to 3614 :
do You understand the FE spectrum from the Tesla Tower/rec/antenna device as
https://en.wikipedia.org/wiki/Ionizing_radiation FeV and FeA alpha,beta,delta,...... gain potential ?
Sincerely
OCWL
stivep
Quote from: lancaIV on December 22, 2021, 08:13:28 AM
to 3614 :
Streamers and sparks are not allowed in the test. Ionization is at its minimum.
I share information only and it is no way I talk someone to perform the Tests. It is at your own  responsibility.
The frequency of testing is  20kHz or below it for EEfSW and  presented winding coil in instruction is for 131kHz.
-good only for  short range of energy transfer  from point A to point B.
Wesley
stivep
• How come surface Wave known as Zenneck wave fallows the curvature of the earth?
Quote1901 Guglielmo Marconi the broadcast took place across the Atlantic at a frequency of 30 kHz
. we may assume that it was Zenneck wave that made it happened.
1901 Гульельмо Марконирадиопередача проходила через Атлантику на частоте 30 кГц.
мы можем предположить, что это была волна Зеннека, которая заставила это произойти. https://www.rroij.com/open-access/surface-electromagnetic-waves.php?aid=87345
QuoteZenneck wave is the fact that (aside from the exponential decay factors) its field is inversely proportional to the square root of r, rather than to r itself as would be true for usual free space propagation with a source of finite extent. Again, this is not unexpected; it is simply due to the approximate two-dimensional nature of the propagation problem
http://web.mit.edu/redingtn/www/netadv/zenneck.html This is article of MIT
QuoteJanice Turner and colleagues at Roke Manor Research of Romsey, U.K., have developed a Zenneck wave demo unit. This can transmit high-definition video over a length of conductor covered with dielectric with a bandwidth of up to 1.5 gigabits per second.
https://www.popularmechanics.com/technology/infrastructure/a8778/skimming-the-surface-the-return-of-teslas-surface-waves-15322250/
Excitation and use of guided surface wave modes on lossy media
https://patents.google.com/patent/US10998604B2/en
Wesley
lukaszkwiatkowskii
Fala Zennecka niczego nie sprawia, a tym bardziej tego jak się rozchodzi, jest jedynie reakcją na akcję źródła.
