verpies
Quote from: lukaszkwiatkowskii on January 17, 2022, 04:21:22 AM
Regarding the deflection yoke, the cross sectional area of the core makes a big difference and as far as the composition goes, the finer the ferrite powder, the better, e.g. the cores from past Sony TC sets are much better than from Rubin.
It depends on what you mean by "better", e.g.: saturation level, permeability, AL value, remanence/hysteresis losses at certain frequency.
The aforementioned parameters might be better for a core used in a switching power supply, but could be considered secondary in a device taking advantage of such phenomena as NAR or NMR device where the skin depth and isotopic composition are the primary parameters of concern.
magpwr
Quote from: stivep on January 29, 2022, 02:51:44 PM
How much energy can be extracted from Schumann waveguide using described by Dr Corum  interface and Wesley's method of energy extraction :
Let us take look at first  at how much energy is available.
How much energy is released a year of all the lightning on earth?
About 100 bolts of lightning hit the Earth every second and they average about a billion joules of energy be bolt.
That's 3.1 billion lightning strikes per year, coming to about 3.1 billion billion joules per year, or about 860 billion kilowatt-hours (kwh) of electrical energy per year.
That estimate is pretty rough as some estimates have as much as 5 billion joules per bolt of lightning, pushing it up over 4 trillion kwh/year.
https://earthscience.stackexchange.com/questions/8249/how-much-energy-is-released-a-year-of-all-the-lightning-on-earth
Wesley
hi Wesley,
I have attached something of value in your area of interest regarding transfer of power -
Transference of Electric Power - Single Wire vs Telluric Part 1https://www.youtube.com/watch?v=Je63-2D5bf4
Telluric Transference of Electric Power - MF Band 2 8 Mileshttps://www.youtube.com/watch?v=25C-bHBdF34
Do check his other videos on how he used network vector analyzer to optimize tesla coil...
I have not forgotten on why you have expanded your laboratory in the first place after observing/touching Tariel Kapanadze device...
If i recalled correctly from past message regarding some device which was presented to Tariel which likely have abnormality symptom likely after powering down device.
If Tariel is/was a electrician then he would already know the 3rd harmonics is a more dominant issue in a electrical system than any other harmonics.Please do consider the possibilities.... :D
lukaszkwiatkowskii
Gradacja proszku (nie wiem jak dokładnie po angielsku, dosłownie to powder gradation)- średnia wielkość ziaren proszku całości.
Ziarnistość (granularity)- wielkość ziaren na jednostkę powierzchni.
Myślałem bardziej o zastosowaniu takim jak w urządzeniu Akuli, co do pomiarów to porównanie histerezy i krzywych strat między rdzeniami cewek odchylania z tv rubin a sony.
Co do wykresów mimo tego że sondę zrobiłeś bardziej o statycznej pojemności to wzbudzenie rdzenia występuje przy dynamicznej reaktancji indukcyjnej.
verpies
Quote from: lukaszkwiatkowskii on February 01, 2022, 08:16:03 AM
...direct translation is powder gradation - the average size of the grains in its entirety.
"the average size of the grains" is understandable to me.
Please avoid using the word "gradation" in this context, because in English this word does not have the same meaning as in your language. In English it means "stopniowanie", which when combined with "powder" yields a monstrosity like: "stopniowanie proszku".
Granularity - the size of grains per unit of area.
That makes no physical sense.
Did you mean to write: "Granularity - the amount of grains in one layer per unit of area" ?
I was rather thinking about an application in a device like the Akula's
Does this device behave like a classical transformer ?
as far as the measurement go, it is the comparison of the BH hysteresis curves and hysteresis losses between Rubin and Sony TV yokes.
This has already been done on another forum and has a high yawn factor in application to unconventional devices.
verpies
Regarding the graphs, despite that you made the probe capacitive, the excitation of the core occurs with the dynamic inductive reactance.
I do not know why you added the word "dynamic" to "inductive reactance" as the latter does not occur at all in non-dynamic situations, like with direct current.
Anyway, further experiments illustrate that the capacitive characteristics of this core also depend on the circumferential magnetization of this material performed by a toroidal winding placed far away on the other half of this core (generating 225 Ampturns of MMF).
The frequencies of some peaks become shifted up and their amplitude increases in the magnetized state.
From these experiments it is evident that the core's material can be polarized either by magnetic flux or by electric flux and that there is a definite interaction between them in the core.
IMO such measurements have a lower yawn factor than the BH curve measurements of conventional transformers and are more applicable to an unconventional device like the one depicted in this video
P.S.
I could post S21 graphs which illustrate this shift but I will not because this forum's software is annoying as it gives me no control over the size of displayed images and insists on displaying their full width, which stretches the entire page and makes this thread unreadable on small, low resolution monitors.   Other SMF forums do not have this problem.
I expect that soon someone will start bitching about it and advise me to resize my images, which I will not do in order not to lose details contained within them and then an all too familiar discussion will ensue about whether it is the job of the forum's software to resize and display thumbnails of posted images ...or the poster's.  Are you reading this Stefan ?!
