0 Members and 51 Guests are viewing this topic.
magpwr
Quote from: ramset on March 14, 2022, 07:03:56 AM
Holcolmb energy systems
https://www.newpowerprogress.com/news/holcomb-scientific-research-harnesses-electron-spin-to-deliver-power/8018093.article
https://m.youtube.com/watch?v=vUIK1GZSduo&feature=youtu.be
Mr Holcomb's patents https://patents.justia.com/inventor/robert-ray-holcomb
So it begins
(How's it do what it do ...Where is the energy coming from ??)
Respectfully submitted
Chet K
hi ramset,
Interesting link and they used words like 'Electron spin' and then few sentences later i captured this word in my head 'significantly magnifies power output'So it looks like different people or experts have different way to represent somewhat similar idea. ;D
We humans do indeed think alike at times although we view or do thing differently.
In my rather "recent" video in youtube :) i did talk about singing bowl where we apply ""non-rigid"" slow hand or tool movement in order to achieve higher frequency sound from the singing bowl.Quartz singing bowl Eg:https://youtu.be/PQGisaMbw94?t=63Many members in forum were deceived by older Ruslan video where he applied resonance  "i used the word rigid"  such that frequency in is the same as the frequency output.No different from a step up power supply.
I dabbled with 3rd harmonics to fine tune the system and i also applied 3rd sub-harmonics which you need hv source from tesla coil.Another hint about 3rd sub-harmonics used by Akula is merely comparing which of 4017 divider setting produce the exact on/off period.If anyone ever played with 4017 years ago may know that each divider setting do not give 50% on/off duty.
The HV high frequency  interrupter is another key to accelerate the electrons under 3rd sub-harmonics.The HV can't be too high or too low. ;D ;D ;D
Good Luck.I have explained in the most layman term. :o
No more hints from here...
AlienGrey
Hi If you want to divide by 1.5  50/50  you can do it with a 4076 on the input and feed back
2  4013 / divided by 2 the second devides the modified output of the  4086 from 3 to 1.5
producing 1.5 50/50 the first 4013 needs to be fed back into the 2nd input of the 4076.
Clear as mud ;)
To Divide by 3 =you would need 3 4013 and some  multi input gating feed back chips
Sil
nix85
When we talk about harmonics, first consider one fundamental question.
How come that systems resonate at second harmonic.
Second harmonic is amplifying the resonant oscillation 1/2 of the time
and diminishing it other 1/2 of the time
That is a literal equivalent of pushing a swing and as it reaches half way
push it in the opposite direction with same force.
nix85
I gotta add, obviously, there are many types of resonance, namely
mechanical
acoustic
electromagnetic
nuclear magnetic (NMR)
electron spin (ESR)
quantum wave functions
For acoustic resonance, resonance at harmonics makes sense as waves are nicely packed so that end nodes/antinodes (whether it's open tube or closed on one end) align with the physical dimensions of the tube.
For LC tank as far as i know they do not resonate at harmonics (series lc behaving inductively above res freq and cap below and parallel lc inversely) so that's fine.
For mechanical systems like a swing, they clearly cannot oscillate at second harmonic.
stivep
So it begins
Chet K
the problem with extraordinary claims is that they must be proven.The literature that is provided as well as the information about the technology is insufficient to evaluate the technology.There is no such thing as less energy In then energy Out.Small amount of energy delivered may trigger energy conversion that is using yet another source of energy.for our eyes it will be an illusion of energy magnification as we don't know about that secondary source of energy.if that energy source is paid by somebody else or by nature then we have free energy.
Quote from: magpwr on March 14, 2022, 10:13:49 AM
'Electron spin' and then few sentences later i captured this word in my head 'significantly magnifies power output'S ;D ;D ;D
/electron-spin-resonance#:
Quote from: nix85 on March 22, 2022, 12:29:35 AM
mechanical
acoustic
electromagnetic
electron spin (ESR)
I may have enough of time to get into a more deep and explain how the system works.
Wesley
