0 Members and 31 Guests are viewing this topic.
stivep
Quote from: stivep on January 16, 2023, 04:08:41 PM
BTG 4-5kW/h
Neutrino Power Cube мощностью 5-6 кВт. Бестопливный генератор.
https://www.youtube.com/watch?v=XQM5qzaMpx4
FE   5-6kW/h  for  24h a day
https://youtu.be/6YEO8Qit1Bw?t=54
English
https://neutrino-energy.com/powercube-neutrinovoltaic/
I do not endorse yet  such revelation
I  have  heard about it just few minutes   ago
I need a time to evaluate it.
Wesley
Information delivered  by lancaIV:
The Neutrino Powercube with estimated 11 000 Euros market entry price and 5-6 KW
output per hour means by 10 years capital reamortization,without tax, 2,5 Euro-cents for
each nonstop generated electric KWh.
Birminghams NanoBOXX with 40 US$/KW estimated production costs and assuming
x10 : over head-costs and MLM-end price +- 400 US$/KW would mean
0,46 US$cent/KWh nonstop electric generated energy !
0,46 UScent / 2,5 Eurocents
NanoBOXX,by given condition,80% cheaper than the Neutrini Powercube !
Wesley
magnetstoo
Here is the update-at this point, using 36v @ 160 ma. battery power, I can semi-light 2- 25w parallel 110v bulbs --a 33ohm load--at 15-22 MHz with what appears to be 95% efficiency.
I can get a bit more brightness by connecting the bulbs straight to the batterys.The outside GND is about useless here, though with a 100 pF cap,it does contribute some.
Contrast this with using an AC variable power supply and the GND is almost essential.Though plugging in a small fan in the same outlet will affect the system,occasionally killing the resonance.
--all depends on how its tuned,where the wires are laying,what frequency its running at, etc.Dealing with RF systems is quite different,they run cool if tuned to its max which is a task in itsel
f--lots of 'what if I did this.' After trying to squeeze every last bit of power to light the bulbs,It just one day switched,the voltage went to 28v from 18v and the current dropped to 100ma from 450ma.
Frequency dropped also from 27-33MHz down to 18-24MHz.
  This system is an ongoing project-if  anyone tries it- WATCH the input power from the antennae into the amp.Im using a 560 ohm + 2uH to limit the current and freq so the input is
not overloaded and operates within a small freq band apparently decided by my surroundings.. The big transformer is not needed,amp will still light the bulbs.I tried the transformer
hoping to increase the voltage out--it did not.Transformer is transparent at these frequecies.I found also this trfmr is more compatible with this system because of the low inductance
of the secondary wires.If I got into the 1mH and above range, it barely,if not failed, to work.Im using an 85k pot to adjust the unit off and on because of BEMF from the Trfmr.It being
switched, blew out another IRFD1Z2 output I had to replace.This amp was meant to run at 24v max but Ive shorted all 3 of mine at 24v and now have a 100v IRFD1Z2 as the final, in 2
of them,the third has the input out and not useable yet.Now its the voltage regulators I worry about.--If you try this system, its the tuning that is the bear.Every wire,its placement,its size,
length,every component all make a difference.I started with a 5w 120v bulb.I now seem to be at a point where it does not care much.It turns on consistenly.
System -from my calculation-sees a 514 ohm output load with a single 25w and 240 ohm load with 2x 25w bulbs.My components are in the uH and pF ranges,the system will
occasionally try  27MHz but falls back.Im going to treat this system as an VHF RF system and try shielded cable,the T200-2 ferrite for up to 30 MHz,UNUN,BALUN,loop antennae
output,etc.Note that this is not like my CB where I lit 2x25w bulbs @ 13v 1.4a,that was a fixed frequency,this system is a self-resonant style picking up from my surroundings.
What is unusual is it occasionally tends toward the 27MHz and the lower freq. the CB also tried to fall into.I see this resonant system as holding a microphone up to a speaker.Its a feedback style.
Have you heard about HOLCOMB ENERGY SYSTEMS --for 1 kilowatt in it puts out 3kW.they are on U-tube.ASTRA ENERGY has joined them.Their device looks like a motour stator with another stator
inside.See the video..
magnetstoo
After looking into the amp--which appears ok--.Im sitting here looking at this wide-band Linear amp alone, with a 125v 25w bulb in series with its gnd at 36vdc 80ma and it is "almost" as bright....but if I insert the 1.1uH in series with the gnd---no bulb...Running the 125v 25w directly to the 36vdc battery, brightness is sooo much better at 80ma, than using the amp at 36vdc 15MHz which now appears as a lossy system.---So perhaps this unit may be good for something in experimenting with RF Feedback.I thought I had something to show you guys.
worldcup
any thoughts for this ?
The guy in his other video explained in details ,the schema... check his channel
Construction of Resonance Generators, ver 1.3 (Kapanadze Jabriek)
https://www.youtube.com/watch?v=OAJg9HhGka4
worldcup
Quote from: stivep on February 02, 2023, 10:01:54 AM
Thank you for your video.
what frequency it operates  at?
can you draw schematic?
Wesley
Hello,
Glad you replied  to atleast one of my post ;D
schematic and explanation in this video - https://www.youtube.com/watch?v=Fnj3kn9CiQM
@wesley, please , we need your input on this thread https://overunity.com/index.php?topic=19335.msg573502#msg573502
