0 Members and 25 Guests are viewing this topic.
stivep
stivep
Updated  information about steps of process.
Explanation of the  phases  provided .
Wesley
stivep
 interesting  fact:
https://patents.google.com/patent/US4503013
Quotea two farad capacitor charged to 10,000 volts will store 108 joules of energy which
is approximately the same potential energy in one gallon of gasoline.
However, the gallon of gasoline requires 10,000 gallons of air and a relatively long period of time to release its total energy.
The same energy stored on the capacitor may be dissipated in a millisecond by dumping the charge into a resistive load.
I have in my posession mentioned in the patent  Cober 606 31kW 2.5kV 12.5A  w/exchangeable  plug in generator  module- regulated up to 1 MHz rep rate   and  Cober 605P  24kW 2.2kV too.
Model 606, High Power Pulse Generator, Cober Electronics, Stanford, Conn.31kW 0.05-3000ms pulse. so we talking about  picoseconds rise time ( rise time)
for example  when connected to 200 Ohm resistor in series with RF coil gives  magnetic field to Voltage ratio of 0.05G/V.
These generators works from regular outlet 110V 15A fuse .
They  are very inexpensive now  ( originally  more than  Mercedes).
especially good for  my application  where   I can have RF  pulse  of 31KW into Tesla Coil  winded with  28 gauge of wire  . Because impulse is in ns/us range  wire on secondary will never blow.
Wesley
nightlife
 The trick is to have the capacitor release enough energy to move a 2 ton rolling object 15 miles like the gallon of gasoline can.
worldcup
