0 Members and 31 Guests are viewing this topic.
stivep
Quote from: stivep on February 25, 2023, 10:16:57 PMHigh Power Pulse Generator, Cober Electronics, Stanford, Conn Cober 606 31kW 2.5kV 12.5A  regulated up to 1 MHz rep rate   and  Cober 605P  24kW 2.4kV too.Model 606,.31kW 0.05-3000ms pulse. so we talking about  picoseconds rise time ( rise time)
For example  when connected to 200 Ohm resistor in series with RF coil gives  magnetic field to Voltage ratio of 0.05G/V.
These generators works from regular outlet 110V 15A fuse .
They  are very inexpensive now  ( originally  more than  Mercedes).
Especially good for  my application  where   I can have RF  pulse  of 31KW into Tesla Coil  winded with  28 gauge of wire  . Because impulse is in ns/us range  wire on secondary will never blow.
Wesley
Same as in radars the pulse is  very short DC but  Raise  time and Fall time of  an impulse is  AC that is  ps/ns spike.So it is very characteristic and good (for tuning )
of Tesla coil at longer distances  of A to B energy transfer as Dr James Corum did. Pulse is still  visible to oscilloscope or connected  receiver (Rx)
Exactly the same   is taking place in  nature but lightning doesn't have such  characteristic pattern.
It can be compared to early 1900 spark Tx  on Spectrum Analyzer  it shows as  lobe with dominating frequency.
Because it is  not that easy  for a beginner to tune Tesla Tx/ Rx  to send  energy from NY to Los Angeles:
-  if test receiver (Rx) is in the car it is easy to stop it on the side of the road connect ground
to any resonant circuit acting as an antenna detect  spike ( signal), find leading frequency and  send information to  distant Tesla Coil Rx operator  helping him to tune it.
- However to get energy from the interface  there is a need to have proper antenna  like Tesla coil in vertical position with  spectrum analyzer connected to it   and properly tuned.
So observing spike with  resonant circuit  works only  for line of sight propagation in the air just to know where is approximate  pick of frequency of the spike, while suggested 16-18kHz
for Tesla Coil Tx can be achieved if Tx with  Cober  606 is connected to the tuned  resonant tank . e.g tuned Tesla Coil at Tx - vertical  polarization (this coil  position is a must)
(We talking about  Energy Transfer  from A to B using Air/ Earth  interface for  Zenneck Surface wave trapped in it in TM mode,) however  discovery of  energy in the interface  for  Energy Extraction  is done similar  way
The only difference is that   naturally deposited energy in the air/earth interface in Schumann  Wavguide   has  different pattern and we don't need any Tx at all.
After that you are in business. For more advanced analysis these receivers can be used but they are not   required:
Re: Wireless energy transfer experiments ,Builders board
« Reply #266 on: August 07, 2021, 05:43:55 PM »
something like that is  perfectly good :Re: Wireless energy transfer experiments ,Builders board « Reply #267 on: August 08, 2021, 02:09:26 AM »
Note: Information  provided was  mutually agreed to be published.
Wesley
stivep
My response to the question:
The maximum radio power for AM Broadcasting in America is 50,000 watts .
QuoteIn 1934 the 50,000 clear channel station WLW in Cincinnati went on the air for five years with 500,000 watts.
The most powerful AM broadcast transmitter is 450kW operated by TransWorld Radio, island of Bonaire.
religious station at  800kHz as "Shine 800" and targets audiences across the Caribbean and South America - powerful signal is widely heard in the USA.
Cober 606 (~120 pounds ((220V 15A))  at 32kW  peak  can be pushed to f at 18/16kHz if "tuned" by tank circuit or from 0 to 300kHz if not.- with   peak amplitude in lobe  pick at 5 to 120kHz.
That is pretty similar to average lightning. And that's good for FE from air/earth interface energy  extraction at TM mode experimenters.
The difference between lightning and  Cober signal :
- ~0.03ms DC signal at 31kW having AC leading and falling edge  at ~ ps/us range Perceiving Peak Noise: You Hear The Chirp?/ having characteristic pattern as/at CW. And we know its repeatability rate.
   We'll hear it only using Rx with  BFO. - not a big deal. (/see/ it on Spectrum Analyzer) if untreated  as a lobe having  bandwidth ~300kHz
-  compared to bandwidth of typical  AM station that  is 35kHz  (although is said 10 kHz, extending 5 kHz above and 5 kHz below the assigned center frequency.)
   Cober signal if treated by tank circuit -will be  detected or seen as  having bandwidth 300Hz to 1kHz  having  "gain" ( e.g CW propagates much much much far}
   Cober signal like generators are extremely powerful for Zenneck Wave at Tesla coil vertically polarized  Tx.  good for long range tuning Tx/Rx pair if A to B energy transfer is in mind.
  The nearest similarity  to Cober  can be  spark Tx    https://en.wikipedia.org/wiki/Spark-gap_transmitter     prior to  or at early version of
  1910]Alexanderson alternator that later on was
Quoteemitting up to 200kW, and the apparatus capable of generating frequencies between 14.5 and 17.5kHz.
Lightning will be also  heard as Chirp  below 1 Hz to near 300 MHz, with a peak in the frequency spectrum near 5 to 10 kHz what-is-the-frequency-range-of-lightning at best if your Rx has BFO
   lightning is also DC with AC leading edge and falling edge.  Lightning EM is one of contributors  of energy  trapped in the interface  if  randomly  but highly likely entering it at complex Brewster Angle
   due to the probability factor at worldwide scale, (3.5 million lightning flashes occur daily.) This Energy is dynamic - it means  - energy from interface will be "taken" only in the presence of  tuned load (Rx)
    Re: Wireless energy transfer experiments ,Builders board « Reply #204 on: October 12, 2020, 12:22:12 AM »
    Till now  this form of  energy is totally abandoned and ready to use for anyone.
  Wesley
stivep
look at  first video in previous comment and than go here:
here is another one for cogging
https://youtu.be/9JkREsSFwLA?t=294
Wesley.
stivep
Quote from: garrypm on April 06, 2023, 04:59:41 PM
Hi Wesley,
When you have a few minutes to spare, would you be kind enough to check out this guy,
Mtech Industries - YouTube
He is selling for $350 a kit.
Making very bold claims, though I'm not seeing what all the hype is about.
Greatly appreciated,
Garry
In the video: https://www.youtube.com/watch?v=DWO7WRNYjKw
he is showing true phenomena taking place like if you had - p–n junctionconnected to two electrical terminals  crystal diode  receiver.
Nothing special in it. there  is plenty of RF around and instead of  headset he has much more sensitive LED diode that rectifies RF.
random piece of wire antennas  of Receivers Rx are more  forgiving to impedance mismatch.
In the video: https://www.youtube.com/watch?v=a-kv67a_VZY  he is showing true phenomena taking place
It is Tesla coil with DC powered  generating circuit.  It is not much important how you wind it as long as you have  air transformer  with high  primary to secondary ratio.
Yes CW and CCW right and left winding combination was used by Tariel Kapanadze to lower coil  main resonance frequency but this guy does
it with cash in mind not the knowledge base  .
Nothing special about it.
Based on his comments about "energy from stars" and  "ZPE"  I assume that although the guy is talented young wanderer
he is still flying not so high  or possibly quite low yet - in the area of understanding phenomena in question.
There is nothing wrong in him trying to make some extra cash. You don't want to make it yourself than pay for it if you will.
He is also right about Free energy- means  Energy you don't have  to pay for. however you can do nothing (not much)with rectified nW or mW in peak.
Wesley
ramset
Greetings Wesley
Thank you for taking time to comment!
Reposted your comments From here
https://overunity.com/19422/topruslan/225/ (post 239)
Your Comment is about Krista's documentary video below,
https://m.youtube.com/watch?v=FJtcl25G0i
Krista's you tube channel
https://m.youtube.com/@KristaAlexander/videos
Krista's newest documentary (2nd link above)
Is filled with things I have never seen before.
Hopefully when Dr.Steven Greer's newest Documentary comes out
There will be more explanations?
Here he does interview ( preview) with  Danika Patrick
https://m.youtube.com/watch?v=0mJawfjDLUg
Respectfully
Chet K
PS
Hope the nicer spring weather is finding its way to you !
We need FE solutions.....
Open source FE solutions!
Thanks Grandma
