0 Members and 38 Guests are viewing this topic.
a.king21
Quote from: r2fpl on April 16, 2023, 01:29:07 PM
a.king21: Did Kapa mention a glass container? like an vaccume tube? I've read it before but is it possible?
No, but he wanted to build the first device for us inside a proper aquarium ie under water with some mechanical device working, but I said that was not acceptable.
However, on one occasion he asked me if we can get Deuterium (Heavy water) in the UK.
I said I had heard of it and it could be obtained from specialist suppliers.
Anyway, here is a link to Melnichenko's transformer.
https://www.youtube.com/watch?v=F8c82ABs02M&t=605s
It is claimed to be COP 150%
ie 50% Over Unity.
On one occasion a war was going on and he could not get braided cable, which I took to mean shielded co-ax.
He said the device would not work without braided cable.
He also told me the device worked on high frequency and not high voltage.  I suppose "high voltage" depends on individual understanding.
I think the device works like this:
He generates a few percent OU from the static field. This is done in L2. He then feeds the extra power into L1
Li now has the original power PLUS the extra from L2.
We now have a vortex OU field which would explode if the device did not have a parallel spark gap as a fail-safe.
The grenade coil and all that stuff are necessary for the power transfer L2 to L1.
If he indeed was doing a Tesla thing, then you have all the theory and answers in Don Smith's work.
Kapa also told me the device would overheat if not connected to an earth ground. This is entirely consistent with the vortex theory and not Tesla. An alternative to an earth ground would be the negative of a lead acid battery. (This last part is Tesla)
Why would the device overheat? Think about it: Steve Marks "TPU" overheated after a couple of hours.
If you are getting your electrons from the static field around your device, eventually this would cause heating and overheating.
By using an earth ground you are getting the electrons from the ground and NOT just the air around your device.
Kapandze even tells us he gets the electrons from the air.
High frequency and a modest high voltage do not obey Kirchof's or ohms law. The electricity is mostly on the surface of the wires. Also, HF and HV generate plasma. (As does a spark gap)
Plasma is a whole bunch of atoms with the outer electron forcibly removed. These electrons are then available to enter your device.
Additional electrons would also enter the device due to the high magnetic field created by the plasma and vortex.
onepower
stivep
QuoteIf we assume  the most silly trick - it would be batteries.
I try not to make such assumptions after observing a ufo pull 100G and accelerate to 60,000 mph in under a second. Now it seems strange watching people desperate to make up excuses for anything they cannot understand. After seeing a ufo and a working FE device first hand my perspective changed.
It's strange, you don't believe something that looks like a transformer could do something different. While I saw a craft which could presumably lift off, travel to the other side of the planet and set down in under 10 seconds being conservative. As such, I think most of these FE devices are child's play compared to the advanced technology I saw. So they produced a supposed COP>1, big deal.
That's the thing isn't it?, were not all the same and by no means are we equal. Somewhere another person just invented another FE device and for them everything changed. That's pretty cool...
AC
a.king21
https://vk.com/id285085326
I am 99% certain that this is Kapanadze's secret.
Below is a comparison of Melnichenko's transformer and Kapanadze's.
It is possible that Kapanadze enclosed L2 with a copper tape capacitor to additionally capture the Magnetic field.
Anyway, there is plenty for experimenters to have a go at, just please share your stuff as it's open source anyway.
We do need your help, Wesley, in having a look at Melnichenko's posts to see if he has improved his device.
https://www.youtube.com/channel/UCEtqI2EhN32Mvq7Wp5G9Vpg/videos[/font][/size]
Melnichenko's patent:-
https://patentscope.wipo.int/search/en/detail.jsf?docId=WO2010117306
Also, I enclose his schematic. The diodes are important in defeating losses maybe Lenz but I don't know for sure.
stivep
Quote from: a.king21 on April 16, 2023, 09:04:07 PM
I'm not in my office for  few weeks now.
I can write simple comment in 3 minutes however in most of the day I'm unavailable.
But I'll do my best.
Wesley
Sergh
My opinion about Melnichenko:
- there is no free energy in his devices. Ordinary devices he mystifies as overunity. We did not watch the video of the device functioning without external power sources. Melnichenko does not carry out professional measurements of consumed and produced energy.
About the transformer:
- аny experienced electrician or electronics specialist will tell you how much power such transformers are capable of operating. The transformer is most likely not rewound. Factory white labels and thermal film seem to be present. An ordinary low-frequency transformer on iron plates. Not ferrite, no high frequency.
The transformer has a primary winding wound with a thin wire, let's say 0.5 mm in diameter, and a secondary winding wound with a wire, for example 2 mm. (optimistic). The number of turns for example 1000 and 60. It is physically and geometrically impossible to get anything else from such a transformer, such as 220 volts 0.5 amperes and 12 volts 7 - 8 amperes maximum.
How to get 5 kilowatts from it? This is impossible by magnetic induction on ordinary iron transformer in such dimensions and weight.
To understand the weight and size problems of power generation, I suggest looking at some reviews and testing of portable generators. With a weight of more than 100 lb, of which more than half the weight falls on the electric generator itself, they have difficulty generating even 3 kilowatts.
https://www.youtube.com/watch?v=RN2HvgB0x7I
