SolarLab
Quote from: Sergh on April 17, 2023, 02:41:32 AM
My opinion about Melnichenko:
- there is no free energy in his devices. Ordinary devices he mystifies as overunity. We did not watch the video of the device functioning without external power sources. Melnichenko does not carry out professional measurements of consumed and produced energy.
About the transformer:
- аny experienced electrician or electronics specialist will tell you how much power such transformers are capable of operating. The transformer is most likely not rewound. Factory white labels and thermal film seem to be present. An ordinary low-frequency transformer on iron plates. Not ferrite, no high frequency.
The transformer has a primary winding wound with a thin wire, let's say 0.5 mm in diameter, and a secondary winding wound with a wire, for example 2 mm. (optimistic). The number of turns for example 1000 and 60. It is physically and geometrically impossible to get anything else from such a transformer, such as 220 volts 0.5 amperes and 12 volts 7 - 8 amperes maximum.
How to get 5 kilowatts from it? This is impossible by magnetic induction on ordinary iron transformer in such dimensions and weight.
To understand the weight and size problems of power generation, I suggest looking at some reviews and testing of portable generators. With a weight of more than 100 lb, of which more than half the weight falls on the electric generator itself, they have difficulty generating even 3 kilowatts.
https://www.youtube.com/watch?v=RN2HvgB0x7I
Hi Sergh,
Your probably right about transformers, however have a look at Holcombs (HES) development page. It's quite
interesting and informative.
https://holcombenergysystems.com/
Check the technical part- been discussed here and elsewhere in detail.
Regards,
SL
r2fpl
In the patent it is written often with high frequency. It can't be that transformer. It's just part of item (1) I think.
The fronts that look like the rears are not the same in the drawing in the patent. In the video you can see when he changes the connections
and the return of energy is to the inverter and not to the transformer. However, I do not know this for 100% because the scheme is too simplified if we do not know what is what.
What puzzles me the most is (2) the capacitor! why is it so important that it has been listed as an exact part like the coil.
r2fpl
Quote from: a.king21 on April 16, 2023, 09:04:07 PM
https://vk.com/id285085326
I am 99% certain that this is Kapanadze's secret.
Below is a comparison of Melnichenko's transformer and Kapanadze's.
These are ordinary spacers in transformers separating the two windings. Of course, maybe the transformer is rewound.
I once had an idea: what if we use two different cores in one transformer and apply two frequencies to each separately? Is it possible that Kapanadze put a ferrite core in the iron core?
pix
Melnichenko is  a very  inteesting variation of flyback converter.
In typical flyback:
-magnetic path is closed, no air gaps
-primary (magnetizing coil) is switched on/off, there is no energy harvest from back emf on primary
-primary and secondary are close coupled
In Melnichenko flyback:
-magnetic path is opened, there is a large air gap, secondary is separated from primary
-back emf from primary is captured( blocking diode)
-primary and secondary are loosely coupled,about 10%
In Melnichenko basically weak field from primary coil that is moved away from secondary is magnetizing iron core, and by nonlinear action of core permeability many times stronger magnetic field is created in that iron core. No back EMF is created in secondary during magnetization because of blocking diode- hence no Lenz applies.
Once power to primary is cut , strong magnetic field in the iron core collapses, inducing current in secondary coil wound on that core. Magnetic field from the core permeates surrounding air and only small part of that field influences primary coil.
Magnetic energy is not stored in the closed magnetic core, energy is stored in the air.
Looking at the TMZ company presentation, device is fairy small and reminds a transformer or bigger choke.
Kapanadze 3 KW TMZ Turkey 4 / 4 - YouTube
Cheers,
Pix
r2fpl
I did some tests like Melnichenko's but I didn't get an increase over 1. Yes there is some energy recovery from the core and something seems to be happening but it's all within the energy input.
If Kapanadze mentions Melnichenko, maybe it's just similar, because many devices can be classified as completely different.
However, one needs to remember that someone also found on Kapanadze's computer a diagram of the Budynny transformer, or more precisely, the fuser on the transformer. The sound of an overloaded transformer is clearly audible in the movies, but nothing can be heard in others.
To get 5kW I find it hard to believe that it can be done with HV. The magnetic field is more real. To feel 2kW, see how an induction cooker works. Typically 80-140kHz varies but 2kW of power can be had on 0.5mm or thinner wire. The device itself is light, very light if I only have electricity from the socket :)
