0 Members and 35 Guests are viewing this topic.
Sergh
Quote from: r2fpl on April 18, 2023, 11:49:06 AM
See this trag: https://youtu.be/Z4HCPrB-KB0?t=657   (turn the sound full up)
To demonstrate starting from a small battery, they use a "GreenBox" or "Aquarium" type device as a starter battery to start a "20 kW Hydraulic Generator" type device.
Kapanadze's "Hydraulic Generator" devices cannot be started directly from a small battery. In other videos, to start devices like "Hydraulic generator" without the use of an additional starter device, they use a temporary connection to the 220 volt network.
Quote from: r2fpl on April 18, 2023, 11:49:06 AMAt this point, the device is running already generating FE. Only the moment of switching on the transformer can be heard - the impact of the magnetic field.
Other things can be heard, for example, the initialization of the vibration of the power cells in the coil.https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg576630/#msg576630
endlessoceans
Quote from: Sergh on April 19, 2023, 02:18:07 AM
Kapanadze's "Hydraulic Generator" devices cannot be started directly from a small battery. In other videos, to start devices like "Hydraulic generator" without the use of an additional starter device, they use a temporary connection to the 220 volt network.Other things can be heard, for example, the initialization of the vibration of the power cells in the coil.https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg576630/#msg576630
Its all fascinating on multiple levels
Here is another time it was on German TV with different angles
Kapanadze is either doing a total deception with the toroid fixed to the shaft (which he always removes for security and breaks the device into its components) or this is a real necessity.  IF SO, there are zero volts (with a conventional multimeter) read off the toroid but that wiring leads into the mystery aquarium.  There is a VERY high chance that this is different superluminal energy and what in the tank is essentially his converting  rectifier.
He guards that tank totally and its blocked out.   He happily shows everything else which indicates he thinks the rest of the components in view are less than 5% of the device and nobody can reverse engineer anything.
https://www.google.com/search?q=kapanadze+spinning+discs+free+energy&ei=So8_ZJi5J4-2oATM57WwCg&ved=0ahUKEwiYhtPBrbX-AhUPG4gKHcxzDaYQ4dUDCA8&uact=5&oq=kapanadze+spinning+discs+free+energy&gs_lcp=Cgxnd3Mtd2l6LXNlcnAQAzIFCCEQoAEyBQghEKABOgQIIRAVOgcIIRCgARAKSgQIQRgBUPQFWNMgYJskaAFwAHgAgAHyAogB5iOSAQYyLTEuMTOYAQCgAQHAAQE&sclient=gws-wiz-serp#fpstate=ive&vld=cid:9a8ab641,vid:3thvqFhFIfY
r2fpl
Sergh: The magnetic separator is available in few versions.
The toroid can rotate with the magnet inside if it is a coil and if the magnet is diametrically magnetized.
I don't know what these discs are for, but THIS is coming out of the box. Just like with Green Box
Sergh
Quote from: r2fpl on April 19, 2023, 03:22:13 AM
Do you, as an electrical engineer, seriously assume that the shaft, due to the force from this toroid, can rotate a 20 kilowatt generator under load?  Even if the toroid somehow magically spins the axle, it will start to spin in the opposite direction and break the wires, as it is not properly fixed to the frame. In my vision, this can be only a sensor of rotation speed, or mystification of observers.  :)
Quote from: r2fpl on April 19, 2023, 03:22:13 AMI don't know what these discs are for, but THIS is coming out of the box. Just like with Green Box
The discs are located on the axle shafts, between which there is a wooden insert, on which the spring is wound.
This is a mechanical damper to reduce vibration from hydraulic motors and hydraulic pumps. Construction foam on the walls is also for similar purposes.
Hydraulic motors and hydraulic pumps have problems with rotational vibrations on the shaft.
The hydraulic pump or hydraulic motor is usually connected with an elastic coupling.
In addition, hydraulic motors can have a large torque. Because of this, the drive belt to electric generator may break  during acceleration.
To exclude this, a spring is wound on a wooden shaft between the disks.
Although such a system with two flywheels can purposefully multiply pressure vibrations in the hydraulic line. Maybe this is the reason for obtaining free energy in a certain substance.
r2fpl
Sergh: I agree with you that the toroid cannot be responsible for the movement of the shaft. I just wanted to show how it should work, if it can be taken seriously at all.
Does the toroid detect the position of the shaft? there is such a possibility.
Is there a pressurized system? I never thought about it, but your observation gives me a different perspective on this device. Thank you.
photo: Someone once wrote that in this device she saw something similar to a water pump. hmm...
