Quote from: PolaczekCebulaczek on July 27, 2018, 04:51:18 AM
https://www.youtube.com/watch?v=L8ABhb5wDJ8 Lastest ruslan device, where is the hidden wire?
Remaining in my role as resident skeptic, I reply:
Hidden wire is not necessary when coil form is big enough for batteries containing plenty of energy to power the demonstration shown in the video. We only have the presenter's word that there are no lithium batteries inside the coil form.  Each separate demonstration doesn't need to use the same method of trickery.
16 watts of light power at 220 VAC, a little spark gap, some HV/HF all over the device, less than five minutes of working shown... no problem for a LiPo battery inside the form.
There are plenty of red herrings, as usual. The best red herring, though, as I've often said, is a real fish, and Ruslan appears to know this too, because the devices _do_ work, that is, they oscillate, produce HV, drive loads using the principle noted above by vasik041 and illustrated by my TKoil X, and so forth. When supplied with power, that is.
forest
PolaczekCebulaczek
Quotehttps://www.youtube.com/watch?v=L8ABhb5wDJ8 Lastest ruslan device, where is the hidden wire?
True, its easy do drive  16 watt bulbs for a short while using HV discharges or resonant systems, single wire transmission is a possibility too, all of Ruslan demos can be faked by someone skilled in such art. If I would have a real FE device , then my demos would be long, outdoor, HD and detailed, showing all connections and even live streamed on YT.
Hoppy
Quote from: TinselKoala on July 27, 2018, 07:24:32 AM
My favourite is the Kapanadze Aqua 2 trick using the rather exotic ground wire - copper braided tube to conceal the phase / 'hot' wire.
AlienGrey
Wesley Where are you ? I ask if your in Latvia ? you do know there is a Lunar eclips just starting there !
Strange coincidence don't you think so. Or are you oblivious to cosmic forces but rely on them for energy  8)
https://www.timeanddate.com/eclipse/lunar/2018-july-27
Good Luck AG
