0 Members and 76 Guests are viewing this topic.
forest
a.king21
Quote from: r2fpl on April 22, 2023, 10:48:06 AM
a.king21: The patent says - high frequency and several times. There is no word about HV. That's true.
Tell me what experiments you want to do and I'll tell you if I've done them before or not.
I intend to pulse one side of a cap at various frequencies powered by a 12 volt lead-acid battery.
Obviously, the other side will be earthed. Various caps will be tried.
I intend to see what loads can be powered on the earth side.
Depending on the results the next step is to try looping to see what happens.
r2fpl
Quote from: a.king21 on April 22, 2023, 03:27:38 PM
Obviously, the others side will be earthed. Various caps will be tried.
I like your idea because I haven't done it yet.
AlienGrey
Perhaps I can help with some of your questions:
First  i have seen a low voltage lamp lit conected to the earth, the other end to a tesla coil
and then the low voltage bulb 35 volt changed to a 240 volt filament vesion that lit up too, but no capacitor was used
the frequency was around 4 to 5 mhz you can try it your self if want it did work.
The Tesla coil was isolated just driven with 6  winds at one end with about 20 volts and the driver was run at 15volts
nothing special except the earth about 1/2 wave length. I just coppied another guys findings off you tube.
Normaly things on there dont work or have stuff missing.
That was some time ago now I did try telling Nick on the thread about it but I have found solar pannels a bit safer
I had 5 cats back the none of them would go near it running I lost four of them since and only have one left now
wierd perhaps they got cat covid during the epidemic who knows.
Sil
arhitrade
From one forum:
Hello bro!
I think everything is simpler, somewhere I don't remember exactly Kapanadze was talking about "points", something about ignition or a reel, the conversation was about that, so what am I? the primary coil works on the principle of a bobbin (only its primary ones), i.e. it accumulates energy up to 10 amperes (works from 12 V) and at a frequency of 20 Hz (it can be higher, but there is already a skin effect), so with a duty cycle of 50%, we will have a consumption 40 watts or so, and then this coil charges a capacitor which is connected in parallel with the secondary coil, which has a larger inductance than the first one. the capacitor after the discharge of the primary is charged up to 300 volts, then it is discharged to the secondary inductance at the moment the capacitor is discharged, energy is accumulated in the primary inductance, and so on for several cycles, each discharge of the capacitor increases the coil current by approximately the same value, i.e., the current in it grows linearly, but according to the formula for the energy of the inductance, the energy grows quadratically, after let's say 20 pulses, the current in the second one will be around 20 amperes, then we break the circuit of the second key and discharge the inductance to the electrolyte and the load then the cycle repeats, i.e. we have the key of the second inductance working at 20 times (approximately) lower frequency. I used to give an approximate diagram and the calculations didn't interest anyone, or maybe they didn't catch up with the principle, but this is brief, whoever is interested can calculate with real values, the trick is that the capacitor is charged constantly with one portion of energy, but when working on a coil, it causes the same increase in current with each After all, the inductive reactance of the coil decreases with the toast of the current, even if it remained at the same level, the current would constantly increase by the same amount. in this principle, I think the whole secret of Capa and the classic Tesla circuit with a damped wave, i.e. extinguished.
