0 Members and 35 Guests are viewing this topic.
r2fpl
Quote from: AlienGrey on April 22, 2023, 06:55:21 PM
Perhaps I can help with some of your questions:
First  i have seen a low voltage lamp lit conected to the earth, the other end to a tesla coil
and then the low voltage bulb 35 volt changed to a 240 volt filament vesion that lit up too, but no capacitor was used
the frequency was around 4 to 5 mhz you can try it your self if want it did work.
The Tesla coil was isolated just driven with 6  winds at one end with about 20 volts and the driver was run at 15volts
nothing special except the earth about 1/2 wave length. I just coppied another guys findings off you tube.
Normaly things on there dont work or have stuff missing.
That was some time ago now I did try telling Nick on the thread about it but I have found solar pannels a bit safer
I had 5 cats back the none of them would go near it running I lost four of them since and only have one left now
wierd perhaps they got cat covid during the epidemic who knows.
Sil
It all works but I didn't see FE here. Apparently something is missing here. Maybe a circuit breaker. I don't know.
r2fpl
Quote from: arhitrade on April 23, 2023, 02:15:55 AM
From one forum:
Hello bro!
I think everything is simpler, somewhere I don't remember exactly Kapanadze was talking about "points", something about ignition or a reel, the conversation was about that, so what am I? the primary coil works on the principle of a bobbin (only its primary ones), i.e. it accumulates energy up to 10 amperes (works from 12 V) and at a frequency of 20 Hz (it can be higher, but there is already a skin effect), so with a duty cycle of 50%, we will have a consumption 40 watts or so, and then this coil charges a capacitor which is connected in parallel with the secondary coil, which has a larger inductance than the first one. the capacitor after the discharge of the primary is charged up to 300 volts, then it is discharged to the secondary inductance at the moment the capacitor is discharged, energy is accumulated in the primary inductance, and so on for several cycles, each discharge of the capacitor increases the coil current by approximately the same value, i.e., the current in it grows linearly, but according to the formula for the energy of the inductance, the energy grows quadratically, after let's say 20 pulses, the current in the second one will be around 20 amperes, then we break the circuit of the second key and discharge the inductance to the electrolyte and the load then the cycle repeats, i.e. we have the key of the second inductance working at 20 times (approximately) lower frequency. I used to give an approximate diagram and the calculations didn't interest anyone, or maybe they didn't catch up with the principle, but this is brief, whoever is interested can calculate with real values, the trick is that the capacitor is charged constantly with one portion of energy, but when working on a coil, it causes the same increase in current with each After all, the inductive reactance of the coil decreases with the toast of the current, even if it remained at the same level, the current would constantly increase by the same amount. in this principle, I think the whole secret of Capa and the classic Tesla circuit with a damped wave, i.e. extinguished.
It looks like a double step up circuit.
pix
Quote from: forest on April 22, 2023, 12:33:56 PM
Electrons come from ionized air.
Exactly.
It is an avalanche type process where potential difference is converted into current.
a.king21
Hi, all.
I have just been down "Memory Lane"
Can you believe it's been nearly eleven years?
Anyway, here is the post from the sponsor of Aquarium 2 where I had a small part.
We organized a second device, which never materialized.
Re: Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Quote from: mike140366 on August 08, 2012, 01:17:53 PM
Ladies and Gentlemen,
I am the sponsor and visitor, that went to see TK's invention, on 2 occasions.
My first trip, with a physicist (bilingual in Georgian and English),
was on the 5th to 8th May 2012.
We met TK, his son and twin brothers, who build these devices.
TK builds the important parts.
I'm the guy in the blue shirt, holding the box.
The plastic box weighed about 6-8 kilos and was
shown to run a 2 kw fire (2 bar) for about 4 hours. I paid
TK, via a friend of the physicist, 3000 USD.
This payment was ongoing, as TK was in bad health.
I also, via the friend, paid for TK's medical treatment.
All was well and good. The devise seemed to work without wires attached (except the earth).
I picked up the box, looked underneath, followed the braided earth lead outside to an earth spike (for grounding), touched it and checked it for hidden wires.
We agreed to sponsor TK, to pay for and build a 10 kw 3-phase version,
that could be tested, using multi-meters etc. In the meantime,
I approached 2 government agencies and started visa applications and commercial negotiations.
The return trip, with an RF Electronics expert and a box of test equipment
(list below), was arranged for 26 July until 02 August.
I had a Confidentiality Agreement ready and a Technology Licence contract.
I emailed these legals to TK's lawyer, beforehand. On day 2 of the trip,
I met with TK's lawyer, made slight amends with him to the 2 documents,
printed off and signed the Confidentiality Agreement. The Technology
The licence was to be signed after the tests were carried out.
I had done my part, as agreed. TK, at this point, stated that he was worried about our test procedures.
I emailed his lawyer and stated "I have asked *** to test the machine, to clarify what goes
into the box and what comes out of the box. This will not be invasive testing.
These tests are to prove that there is no outside source of energy and that the energy
output is of good quality. Each test will be approved by TK before we carry them out.
We have rented electrical test equipment to do this:
Neotronics Impact Gas Detector.
Fluke 435 Power Analyser.
Fluke 199 Scopemeter. Radiodetection CAT and Genny.
Monitran VM110. Flir i60.
Mechanical stethoscope.
Basic clamp-meter.
All these machines have standard data logging, to save the results.
We shall take the process of testing very slowly, confirming with TK at every stage.
If we cannot test, we cannot get our government to invest in a manufacturing company,
or sell the power to industry."
We then waited a further 2 days. On the evening of day five,
TK's son came over and showed us a picture of the (supposed)
3-phase machine on his digital camera (a 2" x 1" photo).
We said thank you but stated that testing must take place
for this working arrangement to proceed.
We asked for a full day of testing and we only had 1 day left.
Nothing until 7pm of the last evening before we flew out.
During the previous 5 days, we had promises from
TK that all is well and we could test that day.
Each day we saw nothing. At 7 pm, we were invited by TK to see the box running.
We asked if we could test. He said no.
We politely declined his offer. He called us repeatedly over the next few hours, to try to get us to see his box.
To us, as commercial people, this was just
TK trying to reel us back in, as a big fish that is getting off the hook.
The last contact, by email, from his lawyer, stating that they believed
that this test equipment would find TK's secret. He also stated that
we should risk some more money with TK, for a further 2 months.
By the way, his lawyer amended the Technology Licence to state that
I would pay him 1500 USD a month....
That said it all.
We left Tbilisi at 3 am the following morning and went to the airport.
Who did we see there? TK's son, in the arrivals section.
Probably waiting to receive a new party, to look at the machine that I had paid for.
The total spend on the project was about 20,000 USD.
I am a committed Christian. TK said that this was a gift from God.
I prayed with the man. He rewards me with insults, saying that
I was trying to steal his technology. TK, unfortunately, in my opinion, lives in fear.
His trust is verbal only. He gets financial reward and runs away.
When he was seriously ill, we paid for a doctor to see him and give him life-saving medicine.
This means nothing to him.
Dog-One
Have to wonder if mike140366 has come across anyone
different in the past decade...
