sm0ky2
Quote from: Sergh on April 29, 2023, 03:09:07 AM
Let's continue the review of Kapanadze's video.
Video "Tariel Kapanadze generator 5kWt Aquarium1"
https://www.youtube.com/watch?v=YKmgS6VVcZA
What do the sounds that occur during operation mean?
1. When turned on, the device makes a strong rattling sound, which then subsides.
The sound is very similar to the operation of a vibration pump at low outlet pressure. During operation, the vibration pump probably creates the necessary pressure in some container. In the absence of this pressure, the armature of the electromagnet of the vibration pump hits on the core. When a high pressure is reached, the vibration pump piston needs more force to move, and the electromagnet armature associated with it no longer hits the core during vibrations, so the sound becomes quieter.
In addition, a feedback system is possible. When the pressure sensor detects the required level, it controls the triac regulator, which reduces the amplitude of the oscillation of the pump electromagnet.
2. Strange sounds from the spark gap.
At first it works rarely and aperiodically. Then the spark gap fires more and more often. Then the device is stopped by the operator with comments from observers that "the device is broken".
The device most likely has a microprocessor control in a separate shiny metal box.
The control system check the parameters of the output voltage and current. If there are any problems: voltage drop, frequency change, too much current in the load - the control system automatically changes some parameters of the device.
It can be assumed that rare stimulating discharges in the spark gap are necessary for the normal operation of this version of the device.
Probably at the end of the video, some problems occurred in the device, for example, something burned out, or some kind of tube broke and the component stopped flowing in the amount necessary for work. The control system attempted to compensate for voltage or frequency drops in the load by applying voltage pulses to the spark gap more frequently, for example by charging a storage capacitor at a faster rate. But this did not help, since the defect was fatal and the operator had to turn off the device.
https://youtu.be/YKmgS6VVcZA?t=1350
Or such a situation was specially programmed in the control system to show that the device is still imperfect and further development is required.
Perhaps we should set up our own experiments, based on the technologies Mr. Kapadanze uses,
Except we should state the actual source materials.
Examining his replication of someone else's technology results in missing information and data.
This leads to mystery and confusion.
https://youtu.be/ZYgFuUl9_Vs
Sergh
Quote from: sm0ky2 on April 29, 2023, 11:48:40 AM
I have been experimenting with the usual types of LC resonances for a long time. No free energy found. At resonance, the light bulb is on, but the current consumption increases many times, so that the wires from the power supply melt and burn.
The coil wire is heated, the capacitor is heated. All of these are wastes of energy. An interesting case was when the terminals of a film capacitor quickly warmed up to red. Of course this can be avoided, there are many capacitors and coils that are suitable for high currents and voltages. But it's not interesting because it doesn't work, it can't create real free energy.
r2fpl
Quote from: Sergh on April 29, 2023, 10:42:11 AM
1. But in the aquarium, the sound of the vibration stops completely, and the bulbs continue to glow. How so? "Resonance" is over, but the lights are on?
2. You need a very bad big transformer so that it vibrates so loudly that the sound from the plastic case drowns out the conversation of the observers.
3. A large iron transformer of 2 to 5 kilowatts would weigh too much, more than 10 kilograms. It would be very difficult to lift this device with outstretched arms. This is not visible in the video.
We're guessing for now.
Melnichenko only works with transformers and coils. Ferrite cores and irons. He never showed anything else if his method is similar to Kapanadze's. You will agree that there is also HV and it is a side effect of BEMF. Melnichenko does not use HV but HF. Generator and frequency kHz. What is missing from Melnichenko coils?
See this: https://youtu.be/MSjz6mnqzOI
This is a 50 Hz resonance
a.king21
A better comparison of the Melnichenko transformer and the Kapanadze transformer in the 2004 video.
Because Melnichenko separated the two halves of his transformer, we now have a transmission and receiver system.
What if Kapanadze took the output of L2 and directed it back into L1? Via diodes? Right there in our faces?
Vortex?
Any comments?
Food for thought and experiments?
https://www.youtube.com/watch?v=F8c82ABs02M
https://www.youtube.com/watch?v=jV6CkpPivds
What if Kapanadze used a steel laminate transformer instead of ferrite to limit runaway due to core saturation?
Is there any evidence in his 2004 video of hammers, and steel-cutting equipment?
Are we all just too slow to take 11 years to see it right in front of our eyes?
What do you think?
r2fpl
Quote from: a.king21 on April 29, 2023, 04:59:15 PM
GIA showed a diagram where the L2 coil is connected via a diode to L1. The patent can show it too.
pic: The Kapanadze transformer has no space. Only the coils are separated from each other.
