Sergh
Quote from: nix85 on May 17, 2023, 08:41:22 AM
Relativity of the future will be Relativity given to us by people of planet Iarga. I understand it is impossible for you (and most people here) to even consider, let alone accept that we are being visited by ETs and that they shared their physics with us, but it simply is so and you will be forced to accept it in due time. I have recognized the immense value of this info since many years and have studied the model in depth and have shared it on my blog.
https://vril12.wordpress.com/6-axis-of-time/
In short time-space itself is created by two sets of vibrations offset by 180° so canceling each other along 6 axis of higher dimensional tetrahedron of time, true Relativity is that from perspective of one time axis it appears as if nearby time axis is oscillating at 1/2 its own frequency altho their frequencies are exactly the same. This is the future of Physics, the future of Relativity and quantum physics and Science. You will not hear about 6 axis of time from Einstein or any string theory, you will not hear that it is time that creates space, so it is time-space, not space-time and infinitely more.
Another key thing that mainstream has no idea about is the universal condensing factor 49 i also spoke about already. In short 49 bubbles of ether of highest order join to form 1 particle of next lower plane and so on. This is why density of matter, speed of light and rate of time flow all increase x49 each level/octave higher one goes. It is not an accident that 49 is encoded all over bible.
I have also spoken about fundamental 'atoms' let's call them sub-quarks, called Anu in Theosophy, these are the smallest units of matter and energy of every plane and they are male and female, and have a pulsation like a heart. They are identical in every respect except for the direction of the spin, male Anu channel the substance from higher dimensions to the lower one, and female Anu returns it and closes the circuit.
You can publish this in the yellow press and earn money.
Only this is real benefit.
Oscillation frequencies - study Planck's constants and what is the maximum frequency that can be in our world. Try to imagine this frequency. What type of radiation is it?You will never reach these frequencies by playing musical instruments or electrical discharges on the coil in any way.
In general, the quantum reality of our world can be much more amazing than what you write about. Think about the nature of time, the transition of the universe from the future through an infinitesimal moment of the present into the past. And why do we need a primitive ether when there is something more?
onepower
nix85
QuoteThey all noticed that the interior of the cabin was "toasty warm", as if heated by a strong fire. Moved to locate the source of this heat, town officials found " two highly polished metal mirrors which faced each other, radiating a very great heat in rippling waves" This is a great discovery. It fulfills what Nathan reported in his last testimony.
Back then it was probably a mystery but today we should recognize them as Casimir plates. As well one has to wonder what kind of wavelengths were being radiated. If it was within the microwave spectrum this could explain his health going south.
AC
onepower
nix85
QuoteCasimir plates don't radiate anything, they produce a tiny barely observable mechanical pressure force. So, no, at least not in conventional way. People always try to downplay exotic effects to some known effect, that is not a way to progress.
Exotic is relative and in the eye of the beholder.
The Casimir effect of confining a given EM wavelength in between the plates could cause plates tuned near that frequency to oscillate in themselves. Just as a guitar string begins to oscillate at it's resonant frequencies. I'm not saying this is what was happening only that every effect must first have a cause. Even more interesting is that if the plates were tuned to or near the gap frequency and did oscillate it could have a modulation and/or pumping effect. Now were talking about parametric effects which could maintain the oscillations. Why make it difficult when it seems easy enough to understand?.
QuoteI will add tho, in his lecture Stan Deyo claimed someone did get overunity using Casimir plates by applying high voltage to them.
As for was it healthy, God knows was it microwaves or not, i would guess it was a different kind of radiation.
If the device was in fact radiating "heat" then we know which part of the EM spectrum this should occur. We find the microwave band falls right next to the infrared band, both known to cause external heating effects. Coincidentally, the transition from microwaves to infrared occurs near the the 1mm wavelength. 1mm tolerances are well within our capabilities so again this doesn't seem that difficult to understand. I see very little I would consider exotic and it seems pretty straight forward. I mean, this is a walk in the park compared to most FE devices...
AC
onepower
nix85
Well done and you have presented so many fallacies I'm not even sure where to begin to respond. However I suspect that was the whole point wasn't it?. In any case that was quite the diatribe and it was entertaining... carry on.
AC
Dog-One
Quote from: NickZ on May 17, 2023, 10:47:13 AM
   worldcup:   Thanks for the video link above.  I watched it, but am not convinced of anything at all.   First thing is for it to SELF RUN, and not depend on the input from two external power sources.   And I see no OU there, neither. Plus his scope shots look messy and are unlike the ones from Akula, Ruslan, Stalker, etc, nor any other inventor of self runners. Nor is he showing more out, than in...
   So, until he shows it self running, his "effect generation" is insignificant and is not OU, in my opinion, which proves nothing.
And the main thing he does not speak of is electrostatic induction.
I have become convinced as of late, this is something that must be
considered with any of these devices.  I can assure you that you
can get current without any noticeable magnetic field in the
vicinity of your coils.  Your coils may not even be acting like
inductive devices at all--more like series connected capacitor plates.
Once you see that on the bench, it will change your thinking.
