0 Members and 44 Guests are viewing this topic.
kolbacict
Quote from: Sergh on June 21, 2023, 05:03:31 AM
No, it's the same question. You can transfer energy from one place to another, but it is impossible to get more energy out of it than you spent.
The Carnot cycle does not allow. And the growing entropy of our space.
Nothing will happen if we do not go beyond our space-time continuum.
Magnetocalorics, ferroelectric capacitors (variconds). The Carnot cycle operates with heat, pressure and volume. We will warm our cooled varicond with the warmth of the environment at a certain time of the oscillatory process. The heat energy of the environment will be converted into electrical energy.
это всё дедиван разбудоражил пару лет назад
Sergh
No, that won't work. In any case, to obtain energy, an energy gradient is needed, a transition from a higher state to a lower one. On the contrary, it is impossible to move energy without additional costs. It is impossible to loop the process without additional energy.
In general, this discussion is meaningless. It is impossible to produce energy without a source. This is the end. DedIvan won't help.
bistander
Quote from: rakarskiy on June 21, 2023, 12:39:56 AM
Energy is the derivative of power with respect to time, ...
Hi Rakarskiy,
You got that backwards.
bi
rakarskiy
Quote from: bistander on June 21, 2023, 10:05:16 AM
Hi Rakarskiy,
bi
Mechanical energy is the energy associated with the movement of an object or its position, the ability to perform mechanical work. Work can only be done with force. On the time interval, the application of this force at a certain speed of movement. When performing work on a time interval, ENERGY will be determined.
bistander
rakarskiy, do you have a problem with translation of derivative? Or just problem with physics?
bi
edit.
Quotepower is the time derivative of energy
https://tinyurl.com/Power-formula
wikipedia.org/wiki/Time_derivative
