0 Members and 35 Guests are viewing this topic.
r2fpl
Quote from: Sergh on July 18, 2023, 02:46:14 AM
Are you prepared enough?
https://en.wikipedia.org/wiki/Georgian_scripts
Could he write in Russian? because, as you can see in the movies, he speaks Russian.
Sergh
Quote from: stivep on July 17, 2023, 12:17:02 PM
Thank you very much lankaIV for your contribution:
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2813242
1. This implementation makes sense mainly for long waves or medium waves.
https://en.wikipedia.org/wiki/Longwave
https://en.wikipedia.org/wiki/Medium_wave
https://www.youtube.com/watch?v=IbUhA6Vt6Sk
2. Transmitters for longwaves or mediumwaves are currently being demolished everywhere.
https://www.youtube.com/watch?v=J72Ip6DROdc
https://www.youtube.com/watch?v=g2CvQBnOHvo
https://www.youtube.com/watch?v=Kq1Q8LXIAJk
https://www.youtube.com/watch?v=18INKRJBAsw
3. A large properly sized antenna is required. A large antenna means a wire several tens of meters long, stretched at a considerable height and correctly oriented relative to the transmitter.
4. Electricity output is very small. 0.0x watts, unless the multi-kilowatt transmitter is 5 kilometers away. The energy will be enough to power the receiver with low power consumption. In such devices, it is recommended to use loudspeakers with high sensitivity in order to get sound that is audible without headphones.
5. It is possible to connect to this source a low-power devices, such as LCD clocks, etc.
6. This source is much more efficient:
https://www.alibaba.com/premium/mono_solar_panel_500w.html
Sergh
Quote from: r2fpl on July 18, 2023, 03:04:47 AM
I am not russian.
According to the rules of this forum I can not write in Russian. I respect the community.
In Georgia, if you are especially respected, they speak Russian among themselves, although this creates additional difficulties for them.
Can you speak Georgian in your family if a guest from Georgia comes to you?
r2fpl
Quote from: Sergh on July 18, 2023, 03:40:56 AM
I am not russian.
I don't understand what you want to tell me.
If I know Chinese, I can converse in Chinese.
We don't have to converse in Russian and it's not desirable here except to quote original texts in any language. Only original lyrics don't distort words if you can read it. This is obvious.
The Lloyd Crump priority date ? 1954 ! We are now in 2023,with many IoT-milliWatt -devices !
Comercial solar panels efficiency 1954 and price per Wp ?
Tate ambiental energy harvester ? Output ?
http://rexresearch.com/tate/tate.htm  MilliWatts !
Is H.A.A.R.P. only emittive or also a receiver and converter ?
electronic devices their size 1950' in mass production  ? Millimeter,Micrometer
Today : f.e. http://www.novasolix.com/technology
The technology is based on the rectifying antenna (rectenna), which is used in radio frequency identification (RFID) tags used to track and identify objects. A rectenna harvests ambient wireless electromagnetic energy through an antenna that is attached to rectifying diodes. RFIDs power themselves with received energy put out by scanners. NovaSolix aims to tune CNTs to the sun's full spectrum output to collect a broad portion of energy.
https://patents.google.com/patent/US9917217B2/en
http://www.novasolix.com/vision
There is another way to convert light energy into electricity. Instead of viewing light as photons, light can be viewed as waves of electromagnetic radiation—just like radio waves only at a much higher frequency. The key is to making little antennae which are roughly ¼ the wavelength of light – this captures the energy as a very high frequency alternating current and then to use a diode to convert the alternating current into usable direct current.  Each tiny antenna is roughly 1 micron or 1/10,000,000th of a meter long and made from a carbon nanotube. At one end of the antenna is a diode which can operate at frequencies approach 1 PHz or 1 quadrillion cycles per second. By contrast, AM radios operate at frequencies in low megahertz or roughly a million cycles per second and ideal antennas are roughly a meter long. The difference is a factor of one billion.
Wireless transfer ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19910423&CC=US&NR=5009243A&KC=A#
The present invention is directed to a solar harness apparatus which includes a plurality of solar cells with each having an active surface, that is, a surface which absorbs photons to generate electrical power, and these are arranged in a substantially parallel fashion with the active surfaces all facing the same direction and with the solar cells being stacked in line behind one another. The solar harness includes a plurality of magnets with at least one magnet being located between each adjacent solar cell in the plurality of cells so as to hold the cells in the stacked arrangement without any further support and so as to create solderless contacts therewith. Means is connected to the stack for drawing electric current therefrom. Preferably, the magnets are at least partially wrapped or wound in electrically conductive material so that the conductivity in series is enhanced. Further, the solar harness apparatus may be employed in conjunction with a parabolic reflector so as to work with concentrated solar energy and it may be used in conjunction with means for converting electrical energy to transmittable wave energy and deployed extraterrestrially. Alternatively, the present invention solar harness apparatus may be reversed with power being put into it so as to create a wave energy transmission device.
What  application potential offers a quantum well diods array device ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19941018&CC=US&NR=5356484A&KC=A#
Heatpump,amplifier,loudspeaker,..... or 2electricity converter
wmbr
OCWL
