0 Members and 64 Guests are viewing this topic.
Sergh
Quote from: kolbacict on July 18, 2023, 10:50:51 AM
I can say one thing, the thick copper tube of the inductor is powered through 2Ц106Г diodes.
These diodes has maximum current 10 mA.  Somehow this does not really fit with large pulsed currents.  :o
KZ109 diodes were seen between a copper tube and a bobbin. Visually, they are used as spacers to hold the copper coil over the bobbin.
http://www.155la3.ru/price_kc109a.htm
This diodes is high-voltage column of pulsed diodes. They were used as a damper diodes in horizontal scanning circuit of very old tubes TVs.
Up to 6000 V and 1 ampere per impulse.
If the pulses are short time, it will more.
The diode KZ109 similar to this western diodes:
https://vikiwat.com/en/diode-tv20-1300v.html
Presumably the reason why  are used two diode, connected in different directions with the inductance in the series with one of them:
- if ferrite magnets "from magnetic separators"( (c) Kapanadze )  are placed inside the bobbin and pulsed bidirectional magnetic field applied, these magnets will demagnetized over time.
To prevent demagnetizing of the magnets,  may be Kapanadze maximizes the forward current and minimizes the reverse impulse by adding inductance in series with one diode.
You can read and watch a video about amateur devices for magnetizing permanent magnets. Without a diode between the capacitor and the coil, the magnets are weakly magnetized.
Sorry, I couldn't find anything similar in English:
(Attention to the big diodes connected in series with the magnetizer coil)
https://www.youtube.com/watch?v=iDaFzCmKaJU
https://www.youtube.com/watch?v=vFINyI5GnRY
https://forum-ixbt-com.translate.goog/topic.cgi?id=48:8515-4&_x_tr_sl=ru&_x_tr_tl=en&_x_tr_hl=en
kolbacict
Quote from: Sergh on July 18, 2023, 04:28:22 AM
This is the oldest form of writing. Even using the entire Internet, there will be great translation difficulties. Especially if you have handwritten text.
And also in Georgia, the vigesimal  number system is used.  Maybe that's why Kapanadze achieved out to be a overunity. Because he measured the input power in Russian, and the output power in Georgian  ? ;D
Quote from: Sergh on July 19, 2023, 07:43:35 AM
No КЦ109 !  КЦ106Г
Sergh
Apparently you skipped classes about Kapanadze.  ;D
https://overunity.com/17735/kapanadze-and-other-fe-discussion/dlattach/attach/192242/image//
See KZ109 under the copper coil?
From the other side another such diode. And the third spacer maybe from delay line for the brightness signal from the old TV, used as a high-voltage inductor.
https://9zip.ru/pictures/linii_zaderzhki.jpg
Or in GreenBox used only one diode in series with the coil.
kolbacict
Quote from: Sergh on July 19, 2023, 02:32:24 PM
Yes,I see.  No wonder I had to repair them for many years.
And why is КЦ106 written in the figure then?
rakarskiy
https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg366142/#msg366142
There is another Kapanadze patent first, where he probably discloses the principle of operation of his "Current Amplifier #9"  WO 2008/103129 A1 "INDEPENDENT ENERGY DEVICE"  [PDF].
The autonomous energy device improved in accordance with the present invention starts operating with initial electrical energy obtained from a source of initial energy (15) and subsequently successively generates energy and is characterized in that it comprises a power switch (1), a capacitor (2), points (3), a high frequency generator (4), first filter (5), first spool (6), first frequency controller (7), second filter (8), frequency stabilizer (controller) (9), second spool (10), second frequency controller (11), output (phase) (positive) (12), positive self-power cable (12a), output (neutral) (13), negative self-power cable (13a), neutral (ground) (14), source of source energy (15).
I think that my thoughts and fantasies of an engineer about how Kapanadze's generator is arranged are very close to reality. The operation of the element "Current Amplifier No. 9" is disclosed in another patent, where we have two coils - primary (6) with high voltage, which is regulated through a spark gap (7), and secondary (10), included in the power circuit. In the patent, the connection of the primary power circuit and the "current amplifier" secondary coil (10) is parallel. I in the diagram, on the blue background placed them in series, according to the second patent.  The principle of operation of the element, the current generator by converting the EMF of the high-voltage voltage source and focusing it on the conductor of the power circuit, the coil (10), into a magnetic vortex field, which is essentially the current force.
https://rakatskiy.blogspot.com/2023/07/the-mystery-of-kapanadze-generator.html
