0 Members and 37 Guests are viewing this topic.
Grumage
Indeed, whoa!
I started looking at a two ground system some time back.
https://youtu.be/mRz3oTLicT4
Sadly my own health deteriorated to the point of not being able to continue with experiments.
In the video I mentioned a gentleman who's handle is Dragon, he had developed a circuit that automatically charged a capacitor bank.
Don't forget that most early telegraph routes were " dowsed " to find the best efficiency !   ;) I was taught dowsing as an apprentice whilst training as an electrician for the local water supply company.
Cheers Grum.
cheappower2012
When I was in the old tpu thread,the same thing happened, people
listened to the inventor say something and ran with it.I can't get this to build the device,conclusion it must
be important,this happens in this thread,your being tricked by Kapandaze.In the tpu thread it was the inventor
wants you to build hes device
and would never lie to you,stupidity reined in that thread.In this thread, its a Tesla invention,
it operates at high frequency,the coil construction  is the secret.
Here is another of Kapanadze's devices,the ground wire can not be  two wires Hoppy,
the fan that he uses operates at 220vac ,50 Hz so the output has to be 220 vac, 50hz.
At the max power it draws 14.8 amps times 220v=3,256 watts,the guy takes a current reading.
The ground in my opinion does not do anything, simply a trick to convince you its related to Tesla stuff.
Pay close attention to the two spark plugs no arc coming from them,whats a Tesla with no arc,LOL ;D.
As far as I can tell there is no hidden wire,so the next trick would be hidden batteries
and a dc to 220v inverter,the size of the inverter rules this out,max power 3,256 watts
for a 12 volt dc battery,the current draw would be 271 amps,I'm assuming a 100% conversion rate
for arguments sake,in reality,the current would be much higher.There is no room in the box for a large inverter or
battery that can deliver this amount of current.In my opinion the coil is a very important
part of the device,this is where the current is generated,notice two wires are tied together on the output white coil,in parallel to increase current.My opinion is the current is not generated in an ordinary way but in a completely different manner,this is why its very hard to figure out,you have to look at all the various devices Kapandaze has made. Check it out and discuss it,skeptics,how did he do it.
https://www.youtube.com/watch?v=EH9VhcDZYKg
Hoppy
Hi Cheappower2012. Good to see you contributing to this thread. I agree with most you wrote, other than there not being a hidden / 'hot' wire(s) powering the device. The hidden wire(s) in the video you posted is most likely routed through the wall into and through the channel section of one of the foot arms on the fan. Look closely. Until a more plausible explanation can be put forward, I'll stick with this one.
AlienGrey
Quote from: cheappower2012 on August 05, 2018, 04:13:48 AM
Ah a window sales man,  No spark ! BS whats that Zzzzzzzt and a spark at 1538 ???
Notice the Tesla coil and the TV tripper just behind it for high voltage to the Tesla coil
now look at the Tesla coil it self it's filled with something, and the end high voltage wire is dead thin, one would expect
a really high voltage ark there, but that coil must be resonating at a low frequency with it's length. The spark plugs limit
the high voltage and other things (EV Grey Tube).
I expect the black box on the left is filled with some sort of storage capacitors or is control.
Wesley what is the PCB to the right of the BLACK BOX it appears to have rows and rows of devices, can you comment on it pleas i'm curious ;)
Hoppy
Quote from: AlienGrey on August 05, 2018, 07:49:15 AM
That's not very kind to call Kapanadze a window salesman just because he uses a lot of glass to house his devices.  ;)
The PCB's look as if they are from an old scrap TV, or other junked appliance. Eye candy.
