r2fpl
 Sergh:
I did tests when you can see 24A current clamps on one wire.
Tesla coil gives electricity on one wire!
you will see the same when you give Spark Gap on one wire.
These are the possibilities I know.
Of course, as you say, there may be an additional cable inside, but what about other devices? Of course, it can always be done differently.
Aking21 - says that he saw how the aquarium works and knew how the grounding was disconnected for some time and the device was still working. Was he in league with them? I doubt.
If you have a spark gap on the ground wire, the current clamps see false data, but in the video we see very stable readings of 24A. The number doesn't jump. BUT you can set the power on the spark so that the current clamps will see any amperage. I've tried this and it works fine. I can do a 90A reading with a few Watt spark. However, this is a fraud or a measurement defect.
As for the tesla coil, the measurement is more difficult because we are limited by 400 Hz for the clamp current meter. If the sound is FM modulation then maybe it is the same as what we see on the ground wire. So we have about 360-400Hz of FM modulation with a few Mhz base for LC TT operation.
This is a good explanation. Only one problem remains! 24A is a lot if we have 220V. Then we are talking about a TT that has 24A at the cold end and a voltage of 220V or more and then we have a voltage drop and a filter.
I explained it perfectly :) but where is FE?
One wire,spark,lower/higher - step ...- Volta-ge transformation ,lower/higher frequency,.....
Speed acceleration/deceleration(O Volt : cold ambient ,but : no positive and not negative Volt ! ZeroVoltpoint )
http://www.rexresearch.com/imris/imris.htm
Volt x Ampere per serial connected lamp by ' 3200 lumen same' output !?
3200 lumen/40 Watt
3200 lumen/0,9 Watt
World-record ? ::)
Details/biblio?DB=EPODOC&II
Volt x Ampere per serial connected lamp by ' ? lumen same' output !?
___________________________________________________________
Step by step R&D ! resistor : Ohm-resistance versus inverse Ohm = Siemens-resistance('conductance')
electro-magnetic   electro-static   https://en.m.wikipedia.org/wiki/Siemens_(unit)
technical= artificial   subjective versus objective view point and nomination (re-sistere,cum ducere )
Puzzling,Gedankenspiele,Mindgame
wmbr
OCWL
p.s.: https://overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/msg580529/#new
particle/wave and 'Quantum tunneling ' (nano-tube speed/resistance)
f.e.
https://www.google.com/search?q=borealis+quantum+tunneling+transistor&ie=utf-8&oe=utf-8&client=firefox-b-m
Max Planck : Wirkungsquant,Quantenpaar,Quantenzahl  = Quantum mechanics
https://en.m.wikipedia.org/wiki/Axiom
https://www.google.com/search?q=physics+paradoxons&ie=utf-8&oe=utf-8&client=firefox-b-m
Quantum space and Quantum time let us play with all known Hyper-/Physics'Paradoxon'-s
Where classical Physics Axioms becomes inverse-Axioms processes/effects  !
Gracian philosophy : the Format/Creation ; In-Format-ion/De-Format-ion,fix to volatil,re-/in-/version
In-/ Final : Verdikt ( local,temporal) panta rhei  ;)
Sergh
Quote from: r2fpl on July 27, 2023, 06:11:04 AM
Measuring clamps are intended mainly for measuring sinusoidal alternating current with a frequency of 50-60 Hz.
There may be more advanced clamps that measure direct current or alternating current up to 1000 Hz.
But they are not designed to measure the current of chaotic pulses of megahertz frequency.
These are false displays of current strength.
I remember that after Aking21 trip to Kapanadze, commentators expressed regret that he did not check the ground cable, suddenly a phase wire was hidden inside. But he seemed to check...
About the fact that during the demonstration the grounding was turned off, I didn't seem to read anywhere.
Maybe Aking21 will confirm these facts here?
I don't see any Tesla coils in Kapanadze's video "GreenBox" or "Generator with a jar" that could do this. I see only a bobbin wound with an ordinary thick wire in PVC insulation. This is not what Tesla coils look like.
I explained it perfectly but where is FE?
Even if we saw a classic Tesla coil with a toroid on the hot side, I can't imagine how such a coil could produce, apart the sparks and streamers,  at least some increase in energy, especially in such big amount, 100 times more than it is consumed.
' .... Even if we saw a classic Tesla coil with a toroid on the hot side,
at least some increase in energy, especially in such big amount, 100 times more than it is consumed. ...'
100 times more power translates ,as v³ effect,to 370% speed increase from the electricity/electron gas/plasma base velocity !
Base v=  1 or 100%  + 370 % = 470 % or 4,7
acceleration : v³ = 4,7 x 4,7 x 4,7 ~ 100
In Volt,in Hertz !?
wmbr
OCWL
p.s.: why Nikola Tesla developped his Tesla transformer ? Reading the EE historials !
Because in the 20' from the last century rotative machines in the KHz/MHz range were something financial and by production precision ' comercial : nearly ' impossible !
KHz and MHz in RPM,scaling
f.e. when              50 Hz or 60 Hz     = 3000/3600 RPM 500Hz/600 Hz       = 30 000 /36 000 RPM
KHz                  5000 Hz/6000 Hz   = 300 000/360 000 RPM
MHz                        1 000 000 Hz   =  60 000 000  RPM
Not impossible,but expensive ! Short longetivity from friction parts ,like bearings et cet. !
Comparison : possible flywheel RPM max . ?
https://www.google.com/search?client=firefox-b-m&q=highest+rpm+from+flywheel&oq=highest+rpm+from+flywheel&aqs=heirloom-srp..0l2
Read about EE know-how and price : Charles Steinmetz/Henry Ford I
https://www.smithsonianmag.com/history/charles-proteus-steinmetz-the-wizard-of-schenectady-51912022/
_________________________________________________________________
Henry Ford
was thrilled until he got an invoice from General Electric in the amount of $10,000.
Ford acknowledged Steinmetz's success but balked at the figure. He asked for an itemized bill.
Steinmetz, Scott wrote, responded personally to Ford's request with the following:
Making chalk mark on generator    $1.  :P
Knowing where to make mark         $9,999.   8)
Ford paid the bill.
Law of hysteresis/Steinmetz Law , 'magnetic hysteresis' behaviour  : importance !
https://edisontechcenter.org/CharlesProteusSteinmetz.html
What was so important about the hysteresis?
Steinmetz figured out the mathematics involved in hysteresis.
Hysteresis loops show the behavior of magnetism in materials.
Understanding magnetism in iron cores was and is still key to design of motors, generators, ballasts and other electrical devices.
Steinmetz figured out the great mystery that all the greats of the time (Thomson, Tesla, Westinghouse, Shallenberger, Edison) had been stumped by.
No one before really understood the physics of what they were experimenting with.
This is how young Steinmetz was able to shock the whole field with his paper and presentation in New York.
Understanding electromagnetism became of increased importance in the 1880s as AC power involved growing and collapsing electromagnetic fields in devices.
The behavior of the core materials (usually soft iron) was not linear.
As you move up the curve (see the diagram above) lots of energy is required to magnetize the material.
Than when poles invert (in AC power) notice how as you move around the 'circle' it takes more energy to reverse the polarity.
Different materials have different hysteresis loop shapes.
Depending on how we design the material we can create materials that are easier or harder to magnetise or demagnetize. See our page on Magnetic Recording page to learn more.
Understanding magnetics boils down to quantum mechanics.
It takes a special type of mind with the right educational foundation to understand
But : about hysterese and losts in transformer
COUNTRY=DE&ENGINE=google
kolbacict
Quote from: Sergh on July 27, 2023, 09:12:04 AM
Famous among FE lovers, Atsyukovsky is convinced that TT is over-unit.
But I don't know say anything.I am doubt.  ???
