0 Members and 37 Guests are viewing this topic.
apecore
Quote from: Hoppy on August 05, 2018, 08:24:33 AM
The PCB's look as if they are from an old scrap TV, or other junked appliance. Eye candy.
Or as i read somewhere he is using the PLL part of the TV board
Hoppy
Quote from: apecore on August 05, 2018, 08:34:58 AM
Possibly but that would not add up to his statement along the lines that the device is is so simple you'll laugh.
cheappower2012
Hoppy
You are correct,on the possible hidden wire being run thru the wall.
You would only have to drill thru the concrete a small hole that leads
behind the wall
and place the fan leg to cover it,then connect thru the fans plug.
The only weakness is how smart is the guy that's paying
Kapanadze,is he a fool.A more believable demo would have been
connecting the heater only
close to the device and lifting the device up.I believe that there
are government agencies that
do grab devices that are real but will only act if there's a good
chance that the device is real,with kapanadze its always maybe its real or maybe its fake
its never a certainty one way or another.This video is from 2015 so he must have burned this guy and
moved on to the next victim One thing kills me,lol,when there's talk about
resonating at much higher frequency than 50 Hz, people forget all of Kapanadaze,s devices operate
at 50 Hz not higher frequencies.This does point to two conclusions one its a hidden wire in all cases or
its a brand new method of generating current that's unknown.
In my opinion only the white coil and the black box, is the device,there is a much larger battery hidden,its used to start the device,the 9 volt battery
does not start the device its used to activate a relay,that switches the larger battery.Remember in the 2005 device it took a lot of current to start the device.
apecore
Quote from: Hoppy on August 05, 2018, 08:43:33 AM
Hoppy,
The problem is we don't know which statements are for real.
This means we it can be a "Yes"or a "No"....
On the other hand.."the device is so simple you'll laugh"...  is probablt only valid when its working on the bench in front of you.
Until that,...  looking how much years and how many qualified people have been busy with it,.........  it seems not so simple at all...
Alsi don t forget,... PLL may be a device to gain more efficiency,... holding the synchroisation process fixed.
As it would be working without PLL  more parameters will have bad effect on stability...  (f.i.    Our Nick "Chaotic effect")
Question would be,...  When a PLL is used...  what would it control?
Greetings
AlienGrey
That's not very kind to call Kapanadze a window salesman just because he uses a lot of glass to house his devices.  ;)
Phase locked to the earths resonance (timing) that's not too difficult. You need about 10kv but no flying sparks
just pulsed, just static. possibly regulated.
Notice spark at 15.38 into video
