0 Members and 43 Guests are viewing this topic.
Hoppy
Quote from: cheappower2012 on August 05, 2018, 08:56:40 AM
Hoppy
You are correct,on the possible hidden wire being run thru the wall.
You would only have to drill thru the concrete a small hole that leads
behind the wall
and place the fan leg to cover it,then connect thru the fans plug.
In my opinion only the white coil and the black box, is the device,there is a much larger battery hidden,its used to start the device,the 9 volt battery
does not start the device its used to activate a relay,that switches the larger battery.Remember in the 2005 device it took a lot of current to start the device.
No large battery needed with a hidden 'hot-wire'.
Look closer at the gap between the fan leg and the wall.
Hoppy
Quote from: AlienGrey on August 05, 2018, 09:02:20 AM
Notice spark at 15.38 into video
Kapanadze could have produced sparks just for eye candy. They signify or prove nothing until the rest of the device is properly understood.
Hoppy
Quote from: stivep on August 03, 2018, 12:19:13 PM
My dear Hoppy .
the two grounds controversy:
Think about it as not important. Just not important for time being.
And After you  have done it  and wake up very next day than you can come back to your reality  whatever you feel comfortable with.
Just do it for yourself.
Wesley
Wesley,
I'm comfortable assuming that the devices I have so far seen demonstrated are faked until such time as a plausible alternative explanation surfaces. As Cheappower 2012 correctly points out, these devices are powering their loads at 50Hz, so I see no reason to believe that HV or HF is necessarily required for operation. I respect that you are trying to be helpful but with respect, some of your posts are just coming over as riddles to me at the moment.
apecore
And again we passed another chapter 8) ;D ;D ;D
Hidden batteries/ additional power sources
Does this last post from Hoppy ends the Kapanadze discussion?
Well until we see no proof from Ruslans demonstration (open field/ BMW X5) i guess that one would be legimit?
Or not?
Greetings
Hoppy
Quote from: apecore on August 05, 2018, 10:13:15 AM
Or not?
Greetings
What with a battery buried under a pile of straw as in his last video but concealled more carefully this time!  ::)
