stivep
Quote from: stivep on October 03, 2023, 07:18:59 AM
Sergh thank you very much - fascinating subject.//
//I ordered it to be tried in Baltic sea .
They couldn't  conform  if there  was  "amplification"//
but I was told that  for an eye it look shockingly unexplained.
//but effect at sea is many times stronger or just look stronger many times.
I just woke up . Thank You for your response  I didn't read  yet your comments. Just got my morning coffee.
Simple explanation of the text from above:
Law of physics  says that there is no way to spend 100% and get in return 156%. But
it is easily done in the water wheel, or  driving on the slope of the hill, or wind mill, or water from the river .
That means we know exactly what force of the nature pays for our  energy for free.
So  the experiment in Trojmiasto  used in the process of disintegration of the load, energy initiated by  the spark
affecting the same way the floating base.
and if we return to video  of  Dr Jaynes
https://youtu.be/qkLGSCXOxi8?t=852
We see energy from the process  much greater than energy delivered.
In language of physics it is:
energy released in the process - energy of losses> energy delivered
So Serh  we need water in the right proportion  for the process to start.
There is something special about Baltic Sea water, or any sea water
It is  much easier  to provide experiment than regular tap water or distilled water
Next week I'll have  sample of Black Sea water  for tests.
distilled water is not conductive and its dielectric constant is  interesting
https://www.scienceabc.com/pure-sciences/do-you-think-that-water-conducts-electricity-if-you-do-then-youre-wrong.html
The salinity of the Black Sea is about 18 ppm,
The salinity of the Azov Sea this figure is only 11
Note: Tsimlyansk hydroelectric complex on the Don, affected Azov Sea salinity.
in comparison :
The Baltic Sea is a low-salinity brackish water body 1.
The salinity varies from 0.7% to 0.9% in the surface layers, depending on the location 2 1
Of course we need to  take to consideration Salinity, temperature and stratification
Conclusion and projection:
-Black Sea  objects as well will likely always have right part of  the DUT acting as a load that would resonate.
-Black Sea  objects as well the bigger the better from  the perspective of a load( that includes internal structure
                     of wiring, dielectrics
and elements manifesting  reactive nature  of L, C, between insulators, )
-Black Sea  objects as well will always have condition of right proportion  proportional to its size
Of course we are talking about safety  of "A to B" and its practical applicability at sea. :)
Wesley
Quote from: Sergh on October 04, 2023, 06:51:44 AM
But I do not find in the patent from your link any connection with sources of coherent optical or radio radiation, which are called lasers or masers.
Only sound waves are mentioned there. Then it could be about a sound laser, SASER.
I did not find any real mention of the connection between the patent and the saser or somethis as sound gun etc..
Saser ,1957 ,comercial ?
( Similar, not same :
https://www.theguardian.com/science/2003/apr/03/research.science1  )
Dr.Fruengels work is partly more as today called
https://en.m.wikipedia.org/wiki/Mechanism_of_sonoluminescence
R&D to refind !
His institute and work here also mentioned :
https://link.springer.com/article/10.1007/s00048-015-0122-3
stivep
ramset
Using light pulse for electron research
Nobel Prize in Physics October 3 - 2023
https://m.youtube.com/watch?v=lVI-Ulf5jdI
Thanks Grandma
kolbacict
Why then does the Yutkin effect not manifest itself in the water Marx generator?
It should big vibration when working. (его должно колбасить не по детски) :D (This is an untranslatable idiom.)
or this exist? I don't know. never did one .
