Hoppy
Quote from: Grumage on August 07, 2018, 02:19:23 PM
Evening Hoppy.
Well,  Why not just put a plug on it ? :)
I've just noticed the back to back series connected electrolytic capacitors, not being really well up on electronics how or what value will be seen? Would the circuit become series resonant at 50 HZ?
Perhaps another way of reducing domestic electro smog?? Marginally brightening that dimly lit space perhaps?
Cheers Grum.
This series back-to-back connection allows the combination to work as an AC capacitor with a capacitance of 2200uF (C1 + C2) / 2 in this example. Not a very safe thing to do. However, the general idea is to create a series resonant circuit at 50Hz with the primary windings inductance, which in this example would be around 5mH.
Like the waveforms we have seen from Ruslan, it still all smells very fishy to me.
Good question about whether its an grid 'earthy neutral' or full earth connection. I'm assuming its the latter.
ramset
From Nicks new/old Stiffler  thread today
https://overunity.com/17249/dr-ronald-stiffler-sec-technology/msg524651/#new
https://www.youtube.com/watch?v=66KTJGlbKmM
  Stiffler quote
  Doing final check on the parts to be used in the loop distance test. There will be no single wire, test will be through the earth only.
Thanks Grandma
AlienGrey
Sounds like the original tester had part of his garden or field was alkaline and the other half acidic  ;D ;D ;D
How about some tests on one wire pulsed Tesla coils and or BEMF as in relay coils  ask Nelson
I'm sure he can help.
Void
Quote from: Hoppy on August 07, 2018, 01:43:31 PM
An interesting statement from Ruslan in Wesley's last post:
"So if we do cut the wire, and than, we do connect phase than we will have device working because we share the same common ground . got it!!"
Also: "Every professional knows that system works  on 220V ( Europe)." What do you make of that Grum?
Hi Hoppy. Ruslan is saying the same thing I have already pointed out here a couple of times, i.e.,
if you disconnect the the output from the grenade where it connects to the relay, and instead connect
the hot phase wire from the mains to the same point on the relay, then you can run the device from the mains.
(This will only work if your utility breaker/fuse box on your house or apartment doesn't have a GFI on the circuit being used).
So, just because the circuit may work when connecting the hot phase wire from the mains to that point, it may work
exactly the same when connecting the output wire from the grenade to that same point on the relay, if the grenade is
producing enough power, so it doesn't necessarily at all mean that Ruslan was using a hidden phase wire.
Hello Grumage:
The circuit from Romancorp which Wesley posted is questionable to me because it connects at one end to the mains neutral wire.
You would really want to test with two separate earth ground connections which are completely independent from the mains.
Wouldn't the joke be on all of us if Ruslan is like Daniel Pomerleau, and therefore only
Ruslan can get these devices of his to work due to some special innate ability. :)
(Just kidding.... I don't really think that is the case for Ruslan. :) )
Hoppy
Quote from: Void on August 07, 2018, 07:41:41 PM
That's all the more fishy then IMO.
Thanks for confirming the Romancorp device connection to grid neutral.
