0 Members and 45 Guests are viewing this topic.
Sergh
stivep
Dropbox :since this is more like diary or  storage box I will store here some handy  links that I found to be interesting or important.
So this  is my :
Dropbox #1
High Voltage Electrostatics:  http://www.keelynet.com/
-intro to electets:
htthttp://www.keelynet.com/electret.htmp://www.keelynet.com/indexjan16.html
-Self-Generating Electrical Discharge  Alexander V. Frolov :
http://keelynet.com/energy/frolov1.htm
http://keelynet.com/energy/frolov2.htm
http://www.rexresearch.com/chernetskii/chernetskii.htm                             Plasmatron (this link is partially BS  but has important information)
http://revolution-green.com/high-power-electrostatic-motor-95-efficency/     High Power Electrostatic Motor with 95% Efficency
https://www.youtube.com/watch?v=H6oAZi8Cc5I
three components  we need :
1.electrical  motor 1 or 3 ph.
2. capacitor
3. diode
all of them are present  in the video.
The guy has no idea  about (conditions and components needed):
a. resonance frequency
b.  two grounds ,
But he has Variable Frequency Drives VFD
to get  anything  is needed.
(this video in in relation  with material from above)
https://overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/msg400411/#msg400411  Solar Lab reference links.
Wesley
AlienGrey
Tinsel your a clever guy! any idea how I can generate a 9hz stand alone tone from a freely available crystal by division or knocking out bits ?
Since 9hz appears to be a resonant spacial lock on frequency rather than 8hz, the Don Smith device for one at 35.1khz.
Many thanks
ag
Quote from: AlienGrey on June 10, 2018, 06:17:24 PM
Many thanks
ag
Uh huh. I see you posted a link to my "subharmonic" demonstration video... but the message was lost on the target audience. Oh well.
Meanwhile: this might work for you:
MicroSemi ZL30167: among many other features:
"Four Programmable synthesizers generate any clock rate from 1 Hz to 750 MHz"
https://www.microsemi.com/product-directory/otn-timing/4622-zl30167
Get the exact, stable frequencies you need, beat them together, have a fine party.
Of course if you don't need absolute stability or multiple independent clocks you can generate a reasonable 9Hz signal with a 555 timer chip and a few resistors and capacitors.
stivep
So here  is another factor supporting working model  of Tariel Kapanadze devices  promoted by me
Рабочая модель Тариэля Капанадзе, продвигаемая мной.
На этом острове нет электричества.
Тариэль подключил к устройству нагрузку 10 кВт. в виде лампочек.
Мы знаем что электродвигател без механической нагрузки тянет  больше тока, только в течение первых нескольких секунд .
После этого требуется часть "начального тока". (этот конкретный двигатель ~ 0.71 A при 220V.)
Почему Тариэль нуждался в этом моторе?
Ответ в сообщении, -( сделанны  мной ранее.) Просто прочитайте
Here  below is the picture  form presentation  that  was made on deserted remote island .
There is no electricity on that island.
Tariel had 10kW load connected to the device.  in form of light bulbs
We know that electric motor without mechanical load takes larger current only  during first few seconds and after that  takes   fraction of "start" current.
this particular one ~0.71 A at 220V.
So now THINK MY FRIENDS ...
Why Tariel was in need to have that motor there?
or
as an answer you take   material posted by me earlier?
https://www.youtube.com/watch?v=oXLxTjc9m3k
Wesley
