AlienGrey
Quote from: Belfior on August 22, 2018, 02:52:32 AM
Same thing with the natural gas pipeline. They are heavily grounded to avoid sparking. I think they still debate if the current is inducted from a changing or moving earth's magneric field. The field is not very strong, but over hundreds of miles it accumulates.
My own WTF story is from my parents place. 4 car tyres piled up and the plastic hub caps on top of the pile. Caps had a round steel wire for fastening. My dad touched a hub cap and got shocked. He cursed and pulled away. He went back and touched a cap and was jolted again. Then he thought I had electrified the tyres and he got mad at me. We then inspected the tires and found nothing. 4 tyres on wooden floor. You only got shocked from the hub caps. If you think about it it was 4 alloy rims insulated by the rubber. Then a plastic cap with a wire (antenna?) and you got an effect
I bet the fitter's name was Johnny  ;D Old houses didn't use copper pipes it was ether steel or lead, lead in the late 1890's copper wire was hard to find
If you talked to the old guys you would pick up useful information.
AlienGrey
Quote from: magpwr on August 21, 2018, 01:30:47 AM
hi void and stivep,
I am not sure what kind of coax cable Akula used for Antenna.But it would be nice to know.But i do notice there is a pattern related to coax cable with low Impedance say 48 or 50 Ohms does come with a thicker center copper core.This copper core looks like the only thing would allow the Antenna to stay in place.
I will try awcwire but the only thing i am not comfortable with is the RFQ part instead of the online Cart.
This circuit i attached may be considered old news but new in many ways only after i explain.
When you get radiant energy going watch out if you haven't got over voltage protection it could damage the Mos-Fet
74hc 132 you need a good 6v suppressor like a 1N 5908 across it as it has been known to go back to the regulator as well, also Pic chips don't last long
with radiant, for warned for armed.
AlienGrey
@ Solarlab
Magnesium how would you describe it with respect of the end game you seek? i'm getting confused with your hypothesis.
AlienGrey
Not magnesium MAGNETISUM ! it's my phone it alters words, i have had to use that as I have picked up so many trackers and treats
to my desk top 18 in total of here i presume now deleted.
