0 Members and 44 Guests are viewing this topic.
Belfior
Quote from: apecore on June 11, 2018, 02:46:15 PM
Guys,
I don t know its origin..  or its final doc.
From Gerry Vassilato's book
http://www.shamanicengineering.org/wp-content/uploads/2014/07/Gerry-Vassilatos-Secrets-of-Cold-War-Technology.pdf
http://borderlandresearch.com/book/secrets-cold-war-tech/chapter-1/7
Tesla doing disruptive discharges and projecting scalar waves (just voltage potential) that would manifest into current in distant metallic plates
Belfior
We also found the shocking effect when tapping a stick welder's positive electrode to a large metal plate. Everybody in the room could feel a shock on their face and skin
apecore
Quote from: Belfior on June 11, 2018, 04:02:34 PM
Belfior,
Is it possible to repeat the "test" a several times to see if the effect occurs again?
Maybe ypu could also register some parameters... like voltage.....air moisturecontent etc. to see what the important parametersare?
Greetings
AlienGrey
Quote from: gyulasun on June 11, 2018, 10:39:01 AM
Hi AG,
You may consider these to get a 9 Hz signal:
1)  There is accidentaly just a 9 kHz crystal on sale at ebay ( https://www.ebay.com/itm/263714732731 ) and you divide the 9 kHz oscillator you build from that crystal by 1000 to get 9 Hz. No need for a tube of decade dividers but only 4 pieces...  ;D
2)  There is the NE567 (LM567) tone decoder IC you may know or be aware of. It has a precision RC current controlled oscillator (better than that of say in the NE555) capable of operating from very very low frequencies.
What I think it would also be practical to run the built-in oscillator at 9 Hz and phase lock it to the 9th harmonic of a 1 Hz reference clock you derive from a normal 32.768 kHz oscillator and divider chain used in crytal controlled watches.
Yes,  the 9th harmonic of a 1 Hz square wave may have a small amplitude at 9 Hz but using say a 2nd order active op amp band pass filter for 9 Hz would help to clean up and amplify  the 9 Hz signal component to feed the phase comparator input of the NE567 and establish phase lock with its internal oscillator, that would be your 9 Hz output signal.
Of course you would need to use good quality RC components for the active filter and for the NE567 oscillator (R1C1).  Here is the data sheet: http://www.experimentalistsanonymous.com/diy/Datasheets/NE567.pdf  and pay attention to the several application hints too.  Texas Instruments still manufacturs this IC as LM567, what is more a CMOS version LMC567  too.
Good luck.  8)
Gyula
PS,  Wesley,  sorry for this off-topic...
Gyula thanks for the information I already have a a simple circuit to produce 1hz from 32k768 xtal it' sorting out the 9hz from it that will deserve some thought I already have a couple of LCM567.
cheers
Any way might use a cd4046 and a 4017 divide by 9 should give me the 9hz or any freq 1 to 10 or a chip that has  jam inputs not sure yet depends what bits i have.
AG
gyulasun
Hi AG,
You may find this paper also useful from this site once you fancy CD4046.  :)
Gyula
