AlienGrey
Quote from: Acca on September 23, 2018, 02:18:08 PM
Mag here in Poland there is a very large copper producer KGHM Copper. Some producers add zink to lower the cost of copper and other elements don't presume it's all the same copper wire..
Like Wesley has said isotopes of copper are many .. It may be the impurity that has an affect on the Russian Kapanadze device.. As of yet unknown ...A scientific method was not done here...
Variables are many it's like a combination lock as one adds to the depth of the tumblers in that, the chance to hit the right combination is in the orders of magnitude...randomness will not work trying to unlock that tumbler safe.
Complexity is in the state of mind as to an engineer looking at a suspension bridge it looks very simple to build and yet to an average man it is a hard thing to understand the complexity of individual parts...
As of yet that elusive effect in the " west " is missing.
Acca I don''t have a white coat  nor do I have a doctors degree but I have said and got ribbing back from many, perhaps this might help
it came from else where in this internet  youtube concerning different metals but i will say it again 'iron or steel, this metal the skin effect 'charged
partials are one of the slowest to travel' and the gains are obvious !
Thanks Acca for mentioning this phenomena and Dr Tanju Argun university of Ankara Turkey~
"The Conservation of Energy Law"? edited and quoted.
In 1993 Tom Bearden came up with the idea of "Massless Displacement Current". I was inspired (Tanju Argun) by that.
As you might know   there is a process called "The Skin Effect" where Electrons (charged particles),
before forming a current, must travel from the center of a conductor to the peripheric rim to travel. The time,
the electrons traverse from center to the rim is called the" Relaxation Time". We are talking Microseconds here. So, what I did  here was to simply,
by just letting a big Capacitor to sniff the Potential of a 24 volts Battery for only 100 Microseconds. During these 100 microseconds,
electrons start to move to outside perimeter of the conductor to start the current.
But unfortunate for them time is not enough to form the current.
Instead those trapped electrons just attain a "Potential Gradient "across them.
So, the capacitor gets the Potential Difference across it with minimum current, which is called the "Mass less Displacement Current". In analogy;
the young man "the capacitor", just catches -a glimpse of a passing by super-mini skirted young lady- "the battery". Capacitor is loaded with minimum power.
Ideal case is to use iron wire or doped conductors and plates to block the electrons from forming a current by increasing the "Relaxation Time".
After 100 microseconds, the Mosfet switch opens and disconnects the battery from the capacitor.
AG
nelsonrochaa
Quote from: Belfior on September 23, 2018, 05:07:40 AM
I find this cherkunov guy a bit strange. If he is posting these antigrav videos why doesn't go around the thing with a stick to show no wires? In one video he does,  but only goes in the front of the device. The plates are not level, but the device floats straight? What kinda force is that?
Antigravity was patented by tt brown already:)
antigrav levitation is not same thing like levitation :)  .I made a video showing some sort of levitation some months ago  with diamagnetic materials like aluminum under influence of dielectric fields , where is possible levitate a aluminum even without any wire connected .  https://youtu.be/kXdBKhVG2Bg?t=1
I really don't believe that those videos show any type of real anti gravity process , maybe some sort of levitation but not some type of antigravity  :) .
chears
Nelson Rocha
cheappower2012
On the Cherkunov device:
When someone levitates an object,say thru the use of magnetic fields
the magnetic field is transferring the force of the weight,thru action/reaction
this is not an anti-gravity effect.You are merely pushing against the magnetic field,this provides a lift by repulsion which has a limited range,it transfers the weight to what ever its pushing against.In
hes device,lets say it weighs 3 pounds,you are providing a 3 pound lifting force to counter
the weight of the object,it is not pushing against anything.If it is not a
trick, it is extremely important,could an object escape the earths gravity
if it produced a small up ward force not dependent on chemical fuel.
Consider a balloon with helium it keeps going until it reaches the edge of the atmosphere.
A device if real would keep going until it escaped the earth.
The problem is if its real and he does a good test of hes device the government will move
on him quickly,can't have there enemies have this information.
Right now he would be considered a crackpot.
stivep
https://www.youtube.com/watch?v=iXLWu6jSHQU
https://www.youtube.com/watch?v=bPqEtBYnkmQ
https://www.youtube.com/watch?v=X0WnddW5gZI
https://www.youtube.com/watch?v=0xx_cyo3OX0
https://www.youtube.com/watch?v=3r4wytAjrU
https://www.youtube.com/watch?v=jAsRp4dvJCU
https://www.youtube.com/watch?v=-FsmEwlgF94 (video  from our perspective  valuable as he uses soft iron wires  substituting ferrite core.)
https://www.youtube.com/watch?v=nHjayUoi8L4
https://www.youtube.com/watch?v=ARKHcq-Ee8g
https://youtu.be/-kLkc7uS-r0?t=6 rusting of ferrite particles is usually done in porcelain cylinders.
https://youtu.be/BHuWloNGo6c?t=47 we are not interested with neodynium, we  are interested with process of manufacturing only
https://youtu.be/HhpPwg89j6I?t=70  Wesley's Wayne Kerr  Magnetic Analyzer
https://youtu.be/flkrwW4Ht-I?t=14     Wesley's LCR
https://youtu.be/izzujmKROWI?t=106Wesley's Beta and Alpha
https://youtu.be/hnY1Zbi7sgM?t=21another DIY
https://www.youtube.com/watch?v=z8jybTInqeQ furnace
https://youtu.be/noGGcyPHtdI?t=166 not importanthttps://www.hitachimetals.com/materials-products/soft-ferrites/ni-zn-materials/stress-and-magnetic-field-resistance.php
http://tscinternational.com/tech13.pdf
http://www.fair-rite.com/wp-content/uploads/2015/08/2007.pdf
https://www.youtube.com/watch?v=QvwXMPnbG8k ferrite material
https://www.youtube.com/watch?v=bt_0QcvsIbo    ferrite material
http://www.hpmemoryproject.org/an/pdf/an_1297.pdf
http://www.johnbreslin.org/files/publications/19960900_vpec1996.pdf with HP 4194A ( Wesley's Lab) for Low frequency
second picture
http://www.ieice.org/proceedings/EMC14/contents/pdf/16P2-B3.pdf  for Low frequency
third picture
http://literature.cdn.keysight.com/litweb/pdf/5980-2862EN.pdfhttp://www.datatronics.com/pdf/distributed_capacitance_paper.pdf we do the same  but with low frequency.
Capacitance  of transformer is important  at resonance. In Lithuania Experiment  we had been  at audible LF region.
Strong vibration.
Figure 6 shows the phase angle of current plotted against frequency, using a Hewlett Packard HP-4194A.  The plot is the same coil as discussed in (2). The resonant frequency is 499 KHz
https://www.researchgate.net/publication/254057540_Analysis_of_the_Complex_Permeability_Versus_Frequency_of_Soft_Magnetic_Composites_Consisting_of_Iron_and_Fe73Cu1Nb3Si16B7
The complex magnetic permeability of most materials varies with frequency with iron powder peaking when exposed to magnetic fields close to 100 kHz [17].
Iron particles on the other hand have a peak complex permittivity of 50 at around 100 kHz [17].
iron filings are readily available at particle sizes of around 1 μm, and can be readily mixed with water, soil, or in our case, sand particles with average sizes of 1 mm as shown in   ...
Wesley
PolaczekCebulaczek
Cherkunov levitation device is pure fake, I was about to debunk his outdoor demo and make a video using trash can lid but I could not find a suitable place nearby my house (two trees on the sides of an open field) its all about fishing line on bright background (sky) and the stick test is so simple to fake that you would laugh, I can tell you how its done but you will be ashamed that you didn't notice how its done.
There is no way on the world to generate such a lift using weak EM and magnets.
Same thing may be about Kapanadze but not that easy, for kapa-hoax I have some ideas but that involves "displacement ground current" in truly russian (and dangerous) fashion.
Right now I have no time for this stuff, working my ass of to survive in ex soviet poor country (bogactwooo macie w tej amerce nie to co u nas w polszy za miedza u putina )
I'm till working on woobling and vibrating magnetic motor project (not OU but just cool stuff)
Thats my two cents for now.
