0 Members and 25 Guests are viewing this topic.
magpwr
Quote from: AlienGrey on October 02, 2018, 06:43:42 AM
Yes  that is fast it's almost a |X10-9 a charged partials travel about 12" in that time, I made a PCB for that PLL circuit you published and i made it
I couldn't get it to be Equally Waited on the 4046 output gave up in the end and the pick up circuit was also crap, how have you got the decide by 3 etc
connected up ? one way would be to include a 4013 after the 4046.
AG
hi AlienGrey,
That circuit was flawed which i have shown the amendment made merely at the front end LM393N.Take note of the suffix.
You will need to use small blue toroid which is large enough to go over the 3 turns.
I can't stop you for trying with 4046 pll.I run from this pll stuff if i were you. :)
I have attached a obsolete but working  PLL circuit which can lock onto L/C resonance(After 3 turns) between 17khz to 38khz  which was saved for my my reference.Phase shift using just 2 gates 74hc14 after LM393N was implemented in my current circuit.
The distorted waveform i have attached previously needs to be dancing or fluctuating constantly without the HV tesla powered on.
This i think will indicate  there is ionization happening at the kapanadze coil without tesla coil turned on.
This is just one of the key ingredient.
I just remembered to look for this effect which i forgotten to apply after the last Sunday experiment.
I will stick with battery like the last round.The mains powered scope is never the issue because not many ppl know the scope ground is also connected to scope earth.
I may need to redo  the IGBT drive circuit using IR2113 like Akula circuit.But need time to do it on breadboard first.
I have attached image of the semi Tesla Coil then wind as semi Helix coil.Hint was given in Akula video or photo.
I have previously done experiment with full Helix coil which produce the highest current reading to Earth via clamp meter*Used as indicator but not accurate measurement.
Tesla Transponder 2.0 -Interrupter 1.7Mhz https://www.youtube.com/watch?v=Yun3HjsNNKs
AlienGrey
magpwr
Quote from: AlienGrey on October 02, 2018, 05:26:56 PM
Do you mean this one ?  https://www.youtube.com/watch?v=PPHipGkfSAY
How many turns are under the blue tape ??? ??? ??? ??? ??? ???
Hi Aliengrey,
The video about helix coil was posted in my youtube channel link as shown in previous post.Tesla transponder 1.7Mhz.
I can't recall how many turns left on tesla coil.But it's about the primary outer coil length at 4th top winding from the left.
AlienGrey
Void
Hi Wesley. For an alternative view regarding how ferrite or iron etc might be used to produce
free energy, you might be interested in George Bugh's ideas about Spin Waves. I don't necessarily
agree or disagree with his ideas, but I find them interesting. He is a very smart guy.
George J. Bugh Videos:
Spin Waves:
Overview_of_Spin_Wave_Technology_part_1
https://www.youtube.com/watch?v=VDEtPGB13NM
Overview_of_Spin_Wave_Technology_part_2
https://www.youtube.com/watch?v=EEMFqOvViDg
Overview_of_Spin_Wave_Technology_part_3
https://www.youtube.com/watch?v=Ge4Ni3ke2I8
Spin Wave Technology part 1
https://www.youtube.com/watch?v=ZkOuGRU8akA
Spin Wave Technology part 2
https://www.youtube.com/watch?v=HjsL1zfmKvA
Spin Wave Technology part 3
https://www.youtube.com/watch?v=craHcstJJZ0
Spin Wave Technology part 4
https://www.youtube.com/watch?v=izlcZPUMkdA
Gravity (I haven't watched these yet, just found them on his youtube channel):
Where Gravity Comes From, Part 1 of 3
https://www.youtube.com/watch?v=lB5qG5wHJ_s
Where gravity comes from part 2
https://www.youtube.com/watch?v=KSbG1vaxSWE
Where gravity comes from part 3
https://www.youtube.com/watch?v=J02-iLzjFbE
George J. Bugh Book (may not be currently available , goes into a bit more detail than his videos):
https://www.vasantcorporation.com/vc002.php
More Info on George J. Bugh and his Spin Waves ideas:
Spin Waves in magnetic levitation and propulsion:
https://www.vasantcorporation.com/downloads/swt_magnetic_levitation.pdf
