Acca
 "Dr. Le Bon's texts contain secrets – very deep secrets as concerns radioactivity and the various means of releasing the intra-atomic energy of which he is the true discoverer. As has been validated, Dr. Moray often would study these texts of Le Bon in order to further pursue his various directions in the field of materials science and of vibratory dynamics. Presumably, these topics were advanced far beyond what we have been told, although we see very clear indications that Dr. Moray was learning the exact modes of applying techniques which Dr. Le Bon had begun to utilize in his Belgian laboratory."
The Evolution of Matter
The Evolution of Forces
Two texts by Gustave Le Bon
Reviewed by Gerry Vassilatos
https://borderlandsciences.org/journal/vol/46/n02/LeBon_Evolution_of_Forces_Matter_Review.html
It's energy from the nucleus that is Kapanadze secret as the amount of particles from this de-stabilization of Fe in the TV core would be so small that it would require very precise instruments to determine that. As to Free energy it's in the "atom"..
Acca..
Wesley thanks for the history, as I also work in Earth sciences..[/font]
Sergh
Sergh
Yes, the launch for the mass appearance on the forums of the topic of electrets was this video:
https://www.youtube.com/watch?v=qc4jWOKdQQc
in which a foil with perforated holes is removed from the package.
This film looks like a waste of an electret film from the production of electret microphones. I wrote on several forums several messages about electrets and their properties. It was about 10 years ago. :-\ Then the topic of electrets became popular and spread around the world. :o
QuoteBrooklyn Eagle July 10, 1932 Nikola Tesla states: I have harnessed the cosmic rays and caused them to operate a motive device. Cosmic ray investigation is a subject that is very close to me. I was the first to discover these rays and I naturally feel toward them as I would toward my own flesh and blood. I have advanced a theory of the cosmic rays and at every step of my investigations I have found it completely justified. The attractive features of the cosmic rays is their constancy. They shower down on us throughout the whole 24 hours, and if a plant is developed to use their power it will not require devices for storing energy as would be necessary with devices using wind, tide or sunlight. All of my investigations seem to point to the conclusion that they are small particles, each carrying so small a charge that we are justified in calling them neutrons. They move with great velocity, exceeding that of light. More than 25 years ago I began my efforts to harness the cosmic rays and I can now state that I have succeeded in operating a motive device by means of them. I will tell you in the most general way, the cosmic ray ionizes the air, setting free many charges ions and electrons. These charges are captured in a condenser which is made to discharge through the circuit of the motor.
Sergh
Probably it will be interesting. My old experiment with electret.
Someone has read that some high-voltage capacitors are sold by a shorted with external jumper. Because they, even 100% discharged, can independently accumulate a dangerous charge. But not every capacitor can do this. Most can not.
Let's create this feature of the capacitors artificially.
We take an ordinary "old scool" capacitor. For example, from the old Soviet microwave oven, K75-15 1 μf 5000 V.
I chose this. But maybe some other one. I chose based on the fact that the capacitor should be with a combined dielectric. Dielectric - paper and plastic film. And everything is soaked in oil.
The paper does not press through when heated. Otherwise the softened plastic would be pressed and a short circuit formed.
so... let's go..
Very careful! Outdoors, not with combustible materials! Dangerous! Do not repeat!
(I drilled a small hole on the top of the condenser for the escape of gases. But I'm not sure that it's necessary. Depends on temperature.)
We take a small pan. We put the capacitor there. Place a wooden stand under the condenser so that it does not stand on the metal bottom of the pan.  Fill this small pan with oil. Sunflower or similar. We charge the capacitor with high voltage (I had 3.2 kilovolts). Leave it connected.
Heat to near the boiling point of the oil, 227 °Celsius.
We are waiting for 20-30 minutes. Switch off the heating.
After 2 -3 hours, when the oil completely cools, turn off the high voltage and discharge the capacitor with a screwdriver.
It is advisable not to cook in this pan afterwards. If capacitor oil gets there, it can be very dangerous for health.
Connect the voltmeter to the capacitor through 1 gigaohm and observe how the capacitor is self-charged "from the air".
If one terminal of the capacitor is grounded, and the other is connected to a polished ball and blow it with ionized air (from Chizhevsky's chandelier) - the capacitor is charged much faster.
The capacitor charges itself to 100 - 200 volts for 20 - 40 minutes. The effect lasted about 2 weeks, gradually weakening.
Under other conditions, it can be different.
To obtain significant energy in this form is not applicable. Although, anything can be.
Scientists call it "Electrostatic Adsorption"
AlienGrey
Quote from: AlienGrey on June 12, 2018, 05:03:10 PM
Gyula thanks for the information I already have a a simple circuit to produce 1hz from 32k768 xtal it' sorting out the 9hz from it that will deserve some thought I already have a couple of LCM567.
cheers
Any way might use a cd4046 and a 4017 divide by 9 should give me the 9hz or any freq 1 to 10 or a chip that has  jam inputs not sure yet depends what bits i have.
AG
Re above harmonious frequency's that don't appear to modulate your brain and are reported to have other useful properties of use here. :D
the 11.0592mhz xtal and a CD4060 are capable of producing multiple divisions of the 432hz frequency ie 1.382026 mhz will divide by 432 = 3200.
If this is of any use to you, with out going too deep feel free.
AG
