magpwr
Hi Wesley and members,
I am posting this Anomaly related to accelerated frequency output as just discovered from the kapanadze device of Akula.I also considered this device a Electron accelerator device.
The output of the kapanadze coil with 10nf 2kv ceramic cap and 5watt bulb in parallel produce around 36khz unfiltered waveform.In Akula circuit there is a low frequency line filter then a 5nf cap is connected at output.
But the input of  the IGBT gate is driven at around 12khz.This is without powering on the Tesla coil yet.The 26 turns of toroid does seems to play a role only if 40nf 1kv ceramic capacitor is connected at it's output as shown in video.
I am still little lost as this is achieved merely by trial and error method using various hv ceramic capacitor at my disposal.
My youtube video posted today to reveal this Anomaly related to the input and output frequency.Screenshot was extracted from uncut video.
https://www.youtube.com/watch?v=_o2Ecwd71lU
Using resonance nothing new was achieved since output frequency would be the same as the input frequency.Kapandze coil would behave like a step up  transformer but Air core.
Yes i am little lost at this point also because the last round i achieved pure 80khz sine-wave at output only if tesla coil was activated.But 100nf 2kv cap was used at output.But i did not record all the configuration made the last round around 1 year ago.Then took a year break from this device.
Tynoo
Hi Magpwr
Congratulations for your work.The last scheme that is out there...maybe it helps!
See the green and red circle, feeback to the IR 2153 oscillator.
https://postimg.cc/7f8dFy3x
Tynoo
magpwr
Quote from: Hoppy on November 07, 2018, 05:43:50 AM
Magpwr,
https://www.youtube.com/watch?v=JzSBWJu24gU
Hi Hoppy,
I have seen the video have also achieved the damping type of waveform for some other configuration depending on the capacitor value used at output coil.She tried to show 1/2 and 1/3 harmonics as well but the waveform does looks very distorted.
Honestly the hint i have not mentioned  but was shown in Tariel Kapanadze video.
Tariel was actually using much lower frequency via spark plug in order to shock kapanadze coil to self oscillate at a much higher frequency than the input.
If you try pulsing a typical step up coil manually(low frequency)you may get bulb to light from the back emf.
But in order to power higher load there would have to be some kind of high frequency ringing happening in the kapanadze like coil.
This which we have not figured out on how to unlock fully.
Akula was using around 1.7Mhz much higher frequency to achieve similar feat.
The only trick left is how to apply low frequency to unlock kapanadze coil such that it will yield higher frequency.
AlienGrey
Magpwr,
Magpwr and hoppy, both interesting videos isn't it golden ratio you want here?   ie  1,2,3,5 etc
I tried using a pic chip a few years ago to generate the sequence with EW 50/50 outputs it starts to get complicated
with a micro and you need a vast amount of memory and you get jitter and 4 bits is the maximum.
If you look at the TK glass box the backboard has a pile of power transistors and other components
you don't suppose e is using simple logic to get golden ratio numbers and thus harmonics as an accelerator.
Any way to decide by 3 is easy with a CD4013 and a CD4093, as an xor gate it couldn't be easier
I will post a circuit later.
