AlienGrey
everything is energy a wave to be exact
Should I say some of you are completely ignorant?
You do not see immediate money than you do not care about me and anything else.
I do not accuse you about lack of understanding due to the fact that the sucker game is at your level of everyday study.
I'm getting help from Country of Tesla, but not much from you yet.
That's because perhaps we are having issues comprehending how it actually works at this stage.
I don't use ''understand'' as the word means just that to stand-under to admit to a contract of control  :-X its a legal terminology from class levels
unlike to comprehend something ;)
AlienGrey
Quote from: F6FLT on November 11, 2018, 05:50:27 AM
The MEG is a fundamental misunderstanding of Bearden that is tirelessly maintained from year to year as an urban legend, while of course it has never provided any energy.
This misunderstanding consists in believing that a parametric modification is made at a zero energy cost (the Steorn motor was based on the same error). Of course not.
In order for the switching coils to change the permeability of the controlled area, they must supply energy.
E=-dΦ/dt is always correct but different from -L*di/dt when L is not constant. When there is a change in permeability, L changes, and therefore the correct formula is E = -dΦ/dt = -d(L.I)/dt. This means that the product of the instantaneous values of I AND L must be integrated over time.
This is a consequence of the superposition of fields: although permeability is modified when the fields change, two fields from two sources always simply add up at any time but taking into account the instantaneous values of permeability and fields at this exact time.
The fields add they do not multiply! However, a modulation is a multiplication, not an addition. Therefore the flux from the Bearden's switching coils cannot modulate another flux, the result is only the sum of the two at any given time and the counter-EMF from the payload affects both.
Thanks for that I posted it out of interest to others, but at the same time one should note just because someone has a patent on something doesn't mean it works  8).
Also has any noticed backchat on the net that NATO is taking over western world governments in 2030 won't this mean the end of world individual sovereignty and the rule of the military eval flys? the age of Aquarius and the Georgia stones. :-\
AlienGrey
https://www.youtube.com/watch?v=YhjHzdDYRXA
Chet have you been on holiday Wesley already commented ;D ;D on this link last week
AlienGrey
I suppose one could always salvage the nitrate from a cold pack and mix with potassium (salt) minus the sulphate wait to crystal and wala!
see if it works
AlienGrey
The ferro cap re-see charge circuit so what's the difference between this cap and a bunch of super caps or a load of poly film dumping it's
energy into a tank coil at the bottom of a tuned Tesla coil, to get energy out you need to put it in just remember that too frequency and
capsize are critical.
Has anyone tried using a triac instead of a spark gap that way you can lower the voltage but current can then be a problem?
