0 Members and 165 Guests are viewing this topic.
stivep
stivep
corrected link:
http://www.dtic.mil/dtic/tr/fulltext/u2/a197278.pdf
QuoteBarlow and Brown define a surface wave as
"...one that propagates along an interface between two different media without radiation,
such radiation being construed to mean energy converted from the surface-wave field to some other form (Reference 7)."
Since this definition covers a lot of territory, one of the major problems
with the surface-wave literature is
the proliferation of different names for what is essentially the same physical phenomenon (References 2 and 8 )
These  waves:
-Zenneck,
-Norton,
-Sommerfeld-Goubau,
-inhomogeneous, -
radial,
-axial,
-azimuthal,
-lateral,
-creeping,
etc.-are all (at least in some sense) a type of or associated with a type of surface wave.
Throughout this report we will try to clarify all such terms and use them correctly
in association with the appropriate physical geometry or guiding process
From the quote of article  (link above)
we see that:
1. Viziv used Zenneck Wave as one of the names.
2. that may be intentional as:
a- there is  little to none  publicly available  literature about it.
b.-There is  estimated half of a billion dollars  at stake  from the investors.
c.- investors must contribute     and do not understand to much
d.- public must  do not interfere and do not understand to much
2. form of phenomena in question can be ironically simple but just in some part of it
matching one basket of all of mentioned names for Zenneck waves
3.  Viziv might not have patent rights to any of  these waveforms so  how they can protect their investment?
B
y means of scrambling access to  the receiver that must match  the same algorithm
to gain access to energy that is already converted to  Zenneck wave  or any other name  they hide it  at.
By simple words:
You have Viziv transmitter and the receiver is like your satellite dish.
The satellite signal is out. All you need is to access it. and that is what you are paying for
- the code
But if you just couple straight right  into the  Zenneck Wave  or whatever name you give to it they going to go bankrupt.
But if you use your own energy from your own water mill   and use Zenneck Wave as means of transportation than you can sale it to your neighbors
or power your own electric car in withing boundaries of your own area of coverage. ( city , county, state)
Picture :
Red rectangle:  explains controversy   about different names associated with Zenneck Wave
Blue rectangle: explains  simple conditions needed for Zenneck Wave and its associated  other names   for the same,  to exist.
At the bottom  of the page #4  please look at  propagation phenomena and types of waves:
-Transverse electric
-Transverse magnetic TM
Transverse magneticTM  is the wave that is  mentioned in :
https://s3.amazonaws.com/texzon/TexzonTechnologies+Paper+Download/TEXZON_Baylor_Corum_2016.pdf
by Viziv.
And now all you need to do is:
- to use the other names used for the same and google it.
- try to find the sense and possible similarity in wording to article published by Zenneck associate
- Try to match statements for both.
All of that  does not require knowledge, it is just simple way to compare text.
So what might be the outcome of your  work?:
- money
- ideas for new solution, competitive to Viziv.
- freedom from "energy  distribution guys"
- or the best of all.. turning it all to mutual use for general public.- if you can overcome your selfishness.
Wesley
stivep
Quote from: AlienGrey on November 13, 2018, 08:55:46 AM
The ferro cap re-see charge circuit so what's the difference between this cap and a bunch of super caps or a load of poly film dumping it's
energy into a tank coil at the bottom of a tuned Tesla coil, to get energy out you need to put it in just remember that too frequency and
capsize are critical.
Has anyone tried using a triac instead of a spark gap that way you can lower the voltage but current can then be a problem?
Ferroelectric capacitor is a capacitor based on a ferroelectric material.
Traditional capacitors are based on dielectric materials.
1.Ferrocapacitor keeps its state  unchanged till it is changed
Another "animal" that is similar to ferrocapacitor  and using using different names is:
varicap diode, varactor diode, variable capacitance diode, variable reactance diode or tuning diode
2   Capacitor       usually decays  in time by itself
2a Ferrocapacitor usually needs someone to push it for change.
Wesley
stivep
https://agupubs.onlinelibrary.wiley.com/doi/abs/10.1029/RS013i006p00969
QuoteExcitation of the Zenneck wave is examined for both finite and infinit vertical apertures over a homogeneous conducting flat ground.
The infinite vertical aperture with a Zenneck wave variation is found to excite only the Zenneck wave with NO radiation field.
The finite vertical aperture excites a field which is similar to the Zenneck wave near the aperture but resembles the usual ground wave at large distances.
Numerical results for various aperture heights are given for frequencies of 1 and 10 MHz. Both homogeneous ground and sea water paths are considered
From that we know that vertical apertures over a homogeneous conducting flat ground. -Are the one responsible for phenomena known as Zenneck wave with NO radiation field
http://nedyn.com/Goubau_1951-X.pdf    This is original uncut German article in English translated by
James F. Corum, Ph.D.
CPG Technologies, LLC
February 17, 2015
Wesley
ramset
Wesley...PDF here on original uncut ......reads 404 now [Not found
http://www.nedyn.com/Goubau_1951-X.pdfThis is original uncut German article in English translated by James F. Corum, Ph.D.
I thought I checked it when you first posted it was good ...but now NG..at least here in NE USA
Chet
Thanks Grandma
