0 Members and 202 Guests are viewing this topic.
AlienGrey
Quote from: Hoppy on November 28, 2018, 11:37:01 AM
Nick,
Dr. Stiffler refers here to: "a special frequency that's been known about for hundreds of years being picked up by his PSEC. Self-running - yes, so long as the signal is maintained. Have you worked out what this signal is yet? I would stick with your solar panel to get sufficient milliamps needed to light up your LED's to a usable brightness.
Hoppy SPECIAL 'Freq' if you put 13500000 into your calculator both 1+3+5 = 9 remember what John Lennon said about it also 13500000/ both 9 and 8 divide with no remainder, in fact, any number that a multiple of 432 and some others will work
You both mentioned A Gustov I couldn't get that Tesla coil to work the sec is too large and too far away from the secondary input something wasn't right for a start if you wind the sec input winding closer to the Tesla winding you get a sine wave ;)  that's just an ordinary Tesla coil even Tesla couldn't get any gain out of that ;) he pulsed his but if you do that the waveform is the wrong way round (a loss) too many actions without a reaction back The trumpet has to go nose on the left to open out on the right! not the other way round I tried a test rig and mine was the wrong way round  :D :D :D :D :D :D
A few years ago a Russian speaking guy sent me a scope shot of his drive is that fast or what ? notice the frequency it's a bit of a beast with two 8s to back it up  >:( 8)
Hoppy
Quote from: AlienGrey on November 28, 2018, 01:08:57 PM
Hoppy SPECIAL 'Freq' if you put 13500000 into your calculator both 1+3+5 = 9 remember what John Lennon said about it also 13500000/ both 9 and 8 divide with no return, in fact, any number that a multiple of 432 and some others will work
OK, so where is that RF frequency coming from to power Dr. Stiffler's PSEC shown in the video link I posted earlier, as it is not connected to a SG?
AlienGrey
Quote from: Hoppy on November 28, 2018, 01:18:31 PM
every thing i got to work of sorts has had to have an earth and a battery or snake oil to run it,
stivep
Last minute revelation:
From Ansis from Latvia.at 7:30 AM of Latvian Time.
Hi, Wesley! I think I know the answer to the 1000 000$ question.
In my previous post I made a simple discovery, Tariel Kapanadze is ordinary man, genius.
That is it! How he made amplification of energy to 1000X? I listen all his tapes. Resonance!!!+ Synchronization!!!+ Capacitance!!!+ Ground wire, which is Amplifacation source!!!
How to make it  simmmmplyyyy? (smile) Answer is very simple.
We need 555 timer, which works in the frequency of transformer, which is ordinary TV or whatever Hi Voltage transformer with Tesla schematic, diode and Capacitor at the end.
Next, we need Ion Wind channel! We change "gap" and we synchronize all processes of charge/discharge/self charge.
But!!! Ion Wind tube is Not ORDINARY!!! There is section, which "suck the Earth Electrons" and collect all energy in the Capacitor or Battery!!!
LiPo battery or Lead. It is little cheating, but not much!
In fact I was  able to catch that effect, and my 2 mates from Latvia was able to catch it too, but we don't understand, because all go to flames or in big massive explosion! Yes, it's very simple!
Note! When effect comes, 300 Ohm resistor will start burn out! Voltage on battery will start go up. I just play with Ionization...
This is only my observations - in one moment everything will go out of Ohms law.
I don't know how to make "ground electron suction", but that is Kapanadze secret, I know.
All Chubinidzes, SR and others do the same. Magnetic Field is an exchange between processes.
We see fat wires in all setups. It is why there is 5KW.
related to picture #2
Solution of ground electron energy can be taken from/with transformer which we add in the schematic. It is only my speculation!
Wesley
NickZ
   Hoppy:
   In that video I think that he has the oscillator connected only to the grids ground on his SG.That is an old video, so hard to remember,  but he never took the device outdoors away from everything. He thought that he didn't need to. But, he does need to do that. However, I now know that there is no way that stray AC alone could cause the LEDs to be able to light that bright.
