tsl
"This so-called Zenneck wave is simply a vertically polarized plane wave solution to Maxwell's equations in the presence of a planar boundary that separates free space from a half space with a finite conductivity. For large conductivity -- this depends on the frequency and dielectric constant, too -- such a wave has a Poynting vector that is approximately parallel to the planar boundary. The amplitude of this wave decays exponentially in the directions both parallel and perpendicular to the boundary (with differing decay constants)."[/font][/size]
http://web.mit.edu/redingtn/www/netadv/zenneck.html
Hoppy
Quote from: stivep on November 28, 2018, 01:35:29 PM
Note! When effect comes, 300 Ohm resistor will start burn out!
Wesley
I'm not surprised looking at that circuit diagram!
Ansis
It was in old times, when I try to make efficient Ionisation and work with Ion Wind generator. Today I decide to tell about it to Wesley. Idea is simple. Very very simple. Kapanadze is genius.
Hoppy
Quote from: NickZ on November 28, 2018, 01:42:21 PM
   Hoppy:
   In that video I think that he has the oscillator connected only to the grids ground on his SG.
Definitely no ground connection or power supply in that video Nick. Just a loop antenna receiving that 'special' frequency.
stivep
Part #5  Zenneck surface Wave for beginners :
this part will be re edited  during today and more information will be  included.
For these who do not yet realize how important  this study is to the whole world please go to  links  at the bottom of this post.below:
Transmitter and receiver of Zenneck Wave.
Today I'm presenting  principal secrets of the Transmitter of Zenneck Surface wave.
1. Transmitter  (Tx) of Zenneck wave directly comes from Maxwell equation and Zenneck in 1906 made special formulation to these waves.
2. Tx is made  of 2  metal conducting materials (balls- spheres or any other shape) with one directly above the other and the certain distance from the earth.
3. pic 1 there are two regions affected by  electrostatic charge of T1 and T2.
4. 213 is typical signal generator delivering waveform to the 209
5. 209 is regular amplitude and phase  regulator between  T1 and T2 creating corresponding charge Q1 and Q2
  - guided  electromagnetic field is  limited by direction in its electric and magnetic field  such as antenna yagi or by guided  modes
- guided modes
are  surface wave modes of electromagnetic wave  propagation
5a- types of guided modes interesting to us:
TEM- Transverse electromagnetic (like wave directed by Yagi antenna.)
   TE- Transverse Electric
   TM- Transverse Magnetic
Quotehttps://en.wikipedia.org/wiki/Transverse_mode
The TE stands for transverse electric mode.
When the electric field of the signal is perpendicular to the direction of propagation through waveguide, it is called the TE mode.
In this mode the magnetic field components are in the direction of propagation.
The TM stands for transverse magnetic mode
TM mode -the electric    field is in the direction perpendicular to that of propagation, so ONLY the magnetic field propagates within the waveguide,
TE mode -
the magnetic field is in the direction perpendicular to that of propagation, so ONLY the electric   field propagates within the waveguide,
radiated electromagnetic  field is  regular electromagnetic propagation of electromagnetic wave in radial axis (not used in Zenneck wave/surface wave )
- radial  axis
is  propagation from one single point  out radially
6. The device creates two regions Region1 and Region2 with interface ground/air
-Region1 and Region2  are above and below  the interface.
-interface is the boarder  used for propagation of surface wave known as Zenneck wave.
-Zenneck wave  inside the interface  is directional( flat but cylindrical )and is called  guided surface wave mode
- "cylindrical"
will be explained later if needed.
7. By use of  two ( can be more than 2 )charged  e.g spheres, + 209 + 213 we  create polyphase waveguide probe.
word  polyphase means:
    having  several AC signals of the same current but having different phase in the same point in time.
     it is used  in
Quotea complex angle of insertion of an electric field synthesized by the polyphase waveguide probes,
-polyphase waveguide probe provides  phase shift in a ground current that facilitates the launching of a guided surface-waveguide mode on a lossy conducting medium in the propagation interface
-propagation interface is interface ( line)  between ground and air.)
-lossy conducting medium is  a ground   (the earth) in the vertical axis to the interface.the more  far away you are from interface Up/Down ( vertically)the more  of the signal is lost or not existing.
  that means that your losses can be close to zero if Zenneck wave travels  directly in the interface and does not reflect from uneven or nonuniform part of  interface.
guided surface-waveguide mode is the mode used by Zenneck Wave
Selected by date chronology  of posts  about  VIziv  estimated half a billion  US $ investment in energy transfer without the wire.
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526668/#msg526668
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg526966/#msg526966
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527019/#msg527019
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527029/#msg527029
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527045/#msg527045
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527048/#msg527048
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527200/#msg527200
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527240/#msg527240
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527282/#msg527282
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527284/#msg527284
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg527386/#msg527386
Wesley
