0 Members and 214 Guests are viewing this topic.
AlienGrey
Thanks for the friendly clarification I'm glad that's cleared up  :D :D have a good day there.
stivep
 I feel like I need to repeat for you AlienGreey  how to achieve small form factor
of the receiving antenna ( Tariel Kapanadze coil):
That wavelength  of (wire) conducting structure wounded on the torus is shorter than a free-space wavelength at the frequency of resonance.
Therefore, at the primary resonance frequency, the toroidal structure behaves electrically as if its circumference were one free-space wavelength
long when that circumference is actually physically smaller than one free-space wavelength.
Thus an electrically small, resonant structure is achieved
That is why Tariel Kapanadze coil is so small.
By combining a number of the toroidal conducting paths just described and by controlling the relative phases of the electromagnetic energy supplied to each path,
various embodiments of the structure and various antenna radiation patterns may be created.
the conducting paths have opposing senses, i.e., are contrawound.
(wounded  counterclockwise)
-conducting paths
is more than  1 path. but I'm talking about just two
- phases
of each path  in relation to each other are the most important ( crucial).
- and to make it working
you need countrawound,  but there are shapes of an antenna that do not need that. however they need to be  bifilar.
use of ferrite helps but is not always mandatory  that is why  most of FE devices uses ferrites.
- when traditional material if regular  transformer made from plates,  is used, or the core  is wounded as donut of continuous circularstrip
one of techniques
   dividing/ splitting magnetic flux into two controlled path can be applied by
making  slot in the middle of the ferrite core  and pushing in it additional  winding at 90 degrees.
Wesley
stivep
 look up.
this set of  ferrite connection is taken from patent application   not related to Corum brothers
I will make separate video about it and it claims FE 10W input  to 15kW output
The reason of me placing it here is because it uses the same means( mechanism) of  flux control as it is used by probe antenna
Wesley
AlienGrey
Wesley Thanks for device layout the two toroids are easy to get hold of but the U shape would have to be a custom device, however,
would it be possible to mount the permanent magnets on the top of the toroids and a flat ferrite rod over the top depending on the thickness
of the wire wrap.
