0 Members and 27 Guests are viewing this topic.
Hoppy
Quote from: Void on December 13, 2018, 12:17:58 PM
From what I have seen of Kapanadze's demo videos, and I have watched many of them very closely,
they do hold up pretty well to scrutiny.
Like you, I have watched his videos and also thought they stood up fairly well to scrutiny, until I glimpsed this clip from the green box garden video. The suspect cable / wire coming into sight behind the guy operating the green box is going towards the bearded guy who holds the coil of ground cable throughout the video. That was part of the 'trick' in my opinion.
v8karlo
Hi Wesley!
If you have capacitor 10uF 12V full, that is not a lot.How can you raise energy of that cap?You simply put in series that cap with output of HV Tesla coil.If the Tesla coil has output of 1000V, than on your 10uF cap will be 1000+12V.And 10uF 1012 V is a lot of energy. First try with smaller capacity of 1uF. It is lethal.
Fill the cap with low voltage high Amp and put it in series with HV output of Tesla coil, flyback?? (unidirectional pulse, watch the polarity so the output is in series with cap) to raise the voltage of that line.  After cap put in series spark gap so the cap do not bleed before you hit it with HV.
After the spark gap put in series step down transformer. Now you have HV spark of 10uF. A very big spark.!
Load the bullet, fire the bullet!
It is Bootstrap method. How to raise the voltage on cap to drive the mosfet?  With Bootstrap method you can raise Bootstrap cap of 100uF 12V to 100uF 500V easily.  Anyone think of that??
It is also voltage doubler circuit but with spark gap and modified. One phase fill the cap from low voltage source. Second phase hit it serial with HV so the 10uF can jump across the spark gap! Easy! A little bit of practice and you will do it!
It is too simple so nobody can see it.
Picture is from Kapanadze patent. He made mistake and draw it!That's why he made second patent to hide the mistake!
It is serial connection of the coil and capacitor. (Power line and already full capacitor). Voltages are adding on capacitor.
Nothing is violated, it depends on law of serial connection. But not two capacitors. Capacitor and coil. A little bit different.
Remember a Steven Mark story of two currents. One 5V and 5A and second HV. In serial they produce kick.
Kapanadze and Steven Mark are all the same principle. All of them are.
AlienGrey
stivep
tsl
Quote from: v8karlo on December 13, 2018, 01:25:51 PM
Hi Wesley!
Hello there , i have just one question,
How will a 12v rated cap survive a 1000v spike?
