magpwr
Quote from: ramset on December 20, 2018, 01:57:50 PM
sorry to interrupt Magpwr important question ,But I have been trying to get this Link to work ..The work of Andrey Melnichenko discussion and observations ,if tests show promise a topic will be started here.these claims have been made for many many years ...trying to see why its taking so long [if provable]
http://www.overunityresearch.com/index.php?topic=3683.msg70540;topicseen#msg70540
hi ramset,
I have read the article in pdf.I realized that this experiment is somewhat similar to what Akula have shown in his channel some time ago with 2 bulbs.
For simplicity I have attached Akula and the Transgender circuit for everyone to see.
In Akula video what I can recall is the bulb located on the left side of the circuit would dim but the bulb to the right would be brighter.
I have actually tested(In virtual circuit) the interesting part of Akula circuit which the nanosecond pulse generator around 5ns was actually created by 2 transistor connected in series to the gate of IRF840.
This was found to be around 5ns in the virtual settings once it hit the breakdown voltage. This is nicely done with minimal trigger circuit.
This is activated by the sine or square wave fed to the transformer(top) input.In circuit is shown as not connected to anything.
I merely associate these 2 circuits which does the same thing with bulbs but design differently.In Akula circuit the bulb to the left side of the circuit if dim would represent as low current passing through.
I have not dug deeper into it maybe because of other project distraction.But it's definitely worth the time to experiment with one of the 2 mentioned circuit.
Belfior
All this talk about E field not being possible with the H field. So can I create a static electric field and then feed that into a capacitor and if I can't, what might be the reason?
What is stopping me using a Kelvin water dropper to charge a cap?
https://en.wikipedia.org/wiki/Kelvin_water_dropper
tinman
Quote from: Belfior on December 21, 2018, 07:32:41 AM
You can charge a cap with a static field,but as soon as the charges in that static field start to move into the cap,it is no longer a static field.
And when charges start to move or vary in time,a magnetic field then also exists.
Yes,you could charge a cap with a kelvin water dropper,and also with the likes of a peltier module.
But as a cap requires current flow to charge,a magnetic field is formed as soon as current starts to flow.
One question to ask would be this-- when you take a plastic comb,brush it through your hair,and then find that a small piece of paper is attracted to the comb,when the piece of paper was heading toward the comb,did any current flow?,and was a magnetic field also produced?.
The same can be asked when two opposite poles of two magnets are attracted to each other.
We know that a magnetic field already exists,but when the two unlike poles are pulled together,was there any flow of current,and did an electric field exist at that point in time?
Brad
magpwr
Quote from: SolarLab on December 20, 2018, 08:57:23 PM
Hi magpwr,
https://www.youtube.com/watch?v=PuR3TPcf7f8
Might help a bit - paramagnetic Cu...
https://chem.libretexts.org/LibreTexts/Mount_Royal_University/Chem_1201/Unit_2._Periodic_Properties_of_the_Elements/2.07%3A_Magnetic_Properties_of_Atoms_and_Ions
http://periodictable.com/Properties/A/MagneticType.html
  Looks like Cu = paramagnetic  [copper metal] (somewhat affected by magnetic field)
   and   Cu+ = diamagnetic   [copper ion] (not affected by magnetic field) {some theories}.
If the ion(1) is in "Air" (70% Nitrogen [paramagnetic] and 30% Oxygen [diamagnetic]
or an electron particle {or energy wave} moving through the Air [?], or vacuum (CRT) [?].
(1) Ion is basically an atom or molecule where the number of electrons does not equal the total number of protrons,
      yielding a positive or negative charge.
Example: Magnetic field (yoke) action on an electron beam (fast ion stream from hot cathode) directs the charged
electrons to a "pixel" location on a CRT's inner phosphor face. The released energy lights up the pixel.
Magnetic fields steer or deflect the electron beam but do not affect the electron speed, the HV [grid] does that.
[ ??? I could be wrong] It's a complex process at this detailed level and there are conflicting theories to pick from.
https://www.youtube.com/watch?v=sENgdSF8ppA
Lots of "stuff" to ponder and sort out!
hi SolarLab,
I appreciate the effort made for trying to explain ion to me.It is not a easy thing to fully understand. :)
Since you have brought up CRT which i had read sometime back but forgotten something valuable.
Related to display-HV in crt apart from charging the high voltage plates at the back of crt and accelerates Electron beam.
Going back to nature-
In nature  "ionization" plays a crucial role in tropospheric "cloud formation"
No lightning(HV) can be produced without clouds
Ions->HV
Related to bench experiment-
Need to do the reverse from nature.
Generate HV from tesla coil.
Using HV to generate ions (Likely paramagnetic ions.Wild guess for now) to alter the NMR of Cu.
HV->Ions
AlienGrey
Why bother with that snail form of charge, It's antique junk  ;D A plasma ball would be a much quicker if your really that desperate and you could try to cover the ball in a silver paper ;D to collect the ions but you might need some diodes and high voltage caps as well.
BUT BE AWARE CHARGING A CAP WITH STATIC IS NOT 'SCALAR' BUT IT CAN STILL KILL YOU AND IF YOU USE AN EARTH IT WILL BE MORE LETHAL.
Ps note some countries label mobile phones as GRADE 2 CARCINOGENIC  ;D ;D DUE TO THE MICROWAVE OUTPUT have you tried seeing if thats a form of  scalar?
