0 Members and 31 Guests are viewing this topic.
stivep
The board is Tivar   anti-static plate
made for people working with sensitive electronics.
1.5x12x12 inch
dk 2-5-10
It prevents electrostatic  damage   to components.
Label is shown on my video.
But that only says that you do not  analyze my video  carefully.
As  always  the devil is in details .
However at the end of video  I  used  pad  made from rubber  with Ortec name on it.
- between glass and  plate
Wesley
Void
Quote from: stivep on December 23, 2018, 01:46:23 PM
Hi Wesley. I thought in the video you said it was non-conductive plastic, but I watched the
video just after waking up, so I wasn't too alert yet.  :)
I didn't hear you say it was an anti-static plate. What is the resistance if you measure across it
with an ohmmeter? Does it measure a resistance?
AlienGrey
Quote from: Void on December 23, 2018, 02:55:34 PM
You didn't read Morey's book pdf'S this type of wave whatever you want to call it can eat through glass plastic or any insulator.
and suck energy from you given the right characteristics and a Faraday cage is of no use whatsoever.
https://www.youtube.com/watch?v=sAnfBemgyb4
stivep
Tivar or UHMW Polyethylene is a type of thermoplastic polyethylene that features an extremely high molecular density.
This makes it a durable material, with the highest impact resistance of any thermoplastic presently made.
It has low moisture absorption, a very low coefficient of friction, is self-lubricating, and is highly resistant to abrasion.
Very high resistance.
Protects against electrical charge build-up
But that is not  the most important.
Wire must have an insulation to work with surface wave.
And if winded with  magnet wire it will not work.
Just forget the lightbulb. This is not important.
It is like looking at the  car and thinking is it electric or gasoline or any other fuel operated.
Just look inside   of it...
Do not look at  car front head lights.
Wesley
Georg46
Hi Wesly I've been your followers for a couple of years now - when you took part in our Polish forums. I have to say that I admire your knowledge, analytical and synthetic skills;) as well as your stubbornness, commitment and reasonableness in FE activities.  It seems to me that we have a common "Alma Mater": PG ;)  I am by profession and passion the designer of electronic systems, based mainly on single chip microprocessors, which I'm doing until now, even after I've retired. Coming back after this personal introduction to the subject: I think that a "coupled pair" of two generators generating simultaneously functions such as sine and cosine (i.e. a 90 degree shift) could be easily realized through DDSs (Numerically Controlled Oscillators - NCOs). Then only the power amplifiers on some powerful MOSTEFs, the Tesla coil and fast rectifiers on the secondary side. The question is what frequency the device should work on: do you follow the principles used in the construction of the Tesla coil? I greet you and the Forum members beautifully! Merry, Healthy and Successful Christmas and Happy New Year!!! Jerzy
