0 Members and 209 Guests are viewing this topic.
stivep
Phase shift can be created by use of capacitor or .pricking cable to see if you are at 90
And that is kapanadze . insulation of the electrical wire or HV  wireis of the same value.
one generator is ok.
Andrey Pastukhov even used 50/60Hz and created 90
I agree that antenna must have vertical polarization and it's image needs to be mirror reflected by earth
If you look at Fig 21 it uses flat copper plate with half circles
And is exactly the same as Fig 23 but this one is made from wires and half circles
at kapanadze we see strange coil
That uses polyphase  and is not important if it has 2 or more components
Or if it uses 60Hz and than creates 90
it can create surface wave and by that couple it's-own polyphase component
With Boundary (The earth!! ) of. Schumann waveguide.
origin of energy!
Whatever exist in waveguide  it must impact boundary of it!
Wesley
r2fpl
Quote from: Void on December 27, 2018, 01:24:21 PM
Hi Wesley. Thanks for the reply. I will think it over and see if I can piece it all together. :)
P.S. Wesley, when you saw Kapanadze's demo in person, were you able to tell if his coil
assembly was an air core coil or not?
Kapanadze claimed that there is nothing inside the coil but that does not have to be true if the pipe was made of iron or Cu :)
Belfior
Quote from: Void on December 27, 2018, 11:54:22 AM
Hello Wesley my friend ...and I will say it again as well. :)
We can't ignore Kapanadze's 2004 very simple demo setup just because it doesn't fit in with someone's current pet theory.
Kapanadze appears to likely only have one generator circuit in that setup, and if that is right it is therefore probably
driving the sparkgap. The only other waveform there in that case would be the output from the blue inverter box.
Whatever Kapanadze is doing there appears to be very simple. Wesley if you can explain how what you are
saying ties in with what we see in Kapanadze's 2004 demo, I am listening. It appears though that you instead just
sidestepped this question because you can't explain how Kapanadze's simple setup in 2004 ties in with your latest theories. Yes? No?
Maybe someone gave you some info on Kapanadze's device that you take as credible, but it has to fit with what
we see in the 2004 demo video, no? Can you offer any explanation of how your theories tie in with Kapnadze's 2004
very simple demo setup? That is a sincere question.
I think we need to go further. I think there is a better quality than this https://www.youtube.com/watch?v=3thvqFhFIfY
but the old German document had Tariel showing his generator&motor, but what caught my eye was that he powered it with simple electronics on the front side of the glass box. I think he learned from this and was hiding this in later videos
stivep
https://overunity.com/17735/wesleys-kapanadze-and-other-fe-discussion-forum/msg528913/#msg528913
when I was trying to film inside the coil Tariel helper distracted me, doing  everything possible for me to do not look at it.
And he was successful.  He was scared bit I analyzed it only after the show.
So I did not see inside of the coil.
In comparison to 2004 video  I do not have clear explanation.
I  can fantasize more or less:
The motor with two disk is   very much known structure and it is nothing new. it requires significant current.
Spark gap has significant impact on phase relation of all elements of plasma.
Two discs and rotation  could be related to the structure https://patents.google.com/patent/US4751515A/en
where clearly Mr Corum says about  rotational access that is virtual.( around infinite torus)
But it is to much of assumption to make any sense of it
The regular electrical motors in  Kapanadze device never  had any load on it.
I assumed  it to be just components  of phase shift generating system.
From energy stand point
I was testing two ground structure in South America and it could be that Telluric current is impacted with  Schumann  waveguide and surface wave interaction by means of polyphase.
( surface wave  interaction with  Schumann waveguide boundary) gives us  some sense of energy origin in Tariel device.
Wesley
stivep
I have an idea.
Make copy  of Andrey device.
the coil 5 and coil 7 ( from my video are grounded.)
# 6 transmission line   can be anything. HV cable or coax or  spark  gap just like  Kapanadze  glass table in Turkey.
build Corum receiver.from his patent.( just piece  of wire.)
Make it  at the distance of  few meters in such a way that there is no chance for "air" "EM involvement from that Tx  on  the receiver. Rx.
Connect anything , any indicator to  Rx and play with Tx.( that is Andrey Tx)
You do not need  anything that has higher number than #7 ( look  at my video)
You can also try to have  only 3 and 4 with phase shift squeezing 5
I showed  it in two versions ( one of it is NMR)
forget  about coil #7
just ground #6 and place cap on the top  of #6
You can also try to make #7 winded on Teflon.( the dielectric)
or instead of cap use  nice large piece of polymer .
Wesley
