0 Members and 164 Guests are viewing this topic.
Jeg
Quote from: AlienGrey on December 29, 2018, 02:30:58 AM
Jeg have you got MSpaint? then copy to paint or just save it to download folder, If copied to paint 'select all' then copy' then you have it
to stick where you like  ;D ;D
Thanks mate! ;)
About the topic, i have also stoped beleiving in magic. I just haven't found any energy amplification to any of the projects i worked with! Looks like Steinmetz was right when talked about proportionality in change between all electrical values when it comes to electricity. So for me if there is something in to it then circuits like V8Carlos is the real deal. It doesn't give amplified energy, but a way to reuse again and again the same portion of energy that initially was used, compensating any losses by injecting energy from the battery itself during each cycle. A system of this kind normally would selfrun "for ever".
If this is the case then it is silly easy to confuse people making them to beleive that two oscillators is the real deal, or that the materials are essential for the operation, or that special geometric coil forms can produce OU! :o
About "closed" and "open" systems, IMO i don't believe that a "closed" system exists in electricity. Even a single cable shortcutting a battery creates a magnetic and dielectric field which interacts with the big earth/ionosphere dielectric.
I wish you all a happy new year. ;)
seychelles
THERE IS NEVER SUCH THING AS A CLOSED ELECTRICAL SYSTEM.
FIRST THEY CALL A PUMP A GENERATOR. WELL ENERGY CAN NOT
BE GENERATED AND OR DESTROY. WHEN AN ELECTROMAGNET IS
CONNECTED TO DC POWER, THE MAGNETIC FORCE PUSH OUT
THE INVISIBLE FLUID AROUND IT IS CALL ETHER..ETHER IS WHERE
THE REAL ENERGY IS. WHEN THE POWER IS SWITCHED OFF THEN
ETHER SPRINGS BACK TO IT,S ORIGINAL POSITION AND FORCING
THE SO CALL ELECTRON DOWN THE POWER LINE. BEMF EMF.
v8karlo
 Hi Markus!
Thank you for your fifth mail. I don't have much time these days because of my job.
I will try to answer your question (not all of them).
I choose this one.
What is difference in a number of capacitors in Zero device?
There is non linearity there. It is not obvious. It is kind of hidden.
Let's say that the source current is 1A. With 3 caps in series they will produce 3 x 1A = 3A. With the help of Czero cap the voltage will raise to 525V. (input voltage is AC 220V, Europe)
So 525V / 3 caps = 175V on each cap (C1, C2, C3). So 175V is output voltage.
Now, if we add 1 cap more in series we will have 4 caps in series. They will produce 4A. And the voltage on each will be 525V / 4 = 131V on each cap. Difference in voltage is from 175V to 131V = 44V.
If you add 9 caps they will produce 9A and voltage on each cap will be 525V / 9 caps = 58V.
If you add 10 caps they will produce 10A and voltage on each cap will be 525V / 10 caps = 52V.
Difference of output voltage between 9 and 10 caps in series 58V – 52V = 6V.
Difference between 3 and 4 caps in series is 44V (on output).
Difference between 9 and 10 caps in series is 6V (on output).
See difference here (44V and 6V).That means that with each cap added you gain 1A and after number of caps the output voltage drops only for little. That means that you have to raise input voltage only for a little and you gain always 1A with every cap.
After a 20 caps in series you have to raise input voltage only for the fraction to raise output voltage on that caps but with every cap added you gaining always 1A. It is serial connection law.
What about after 60 or 200 caps? You have to raise input voltage only for 1V or less to gain 1A. There is no limit to this.
What about after 1000 caps? You wanna power your city?
These is easy to me because I played with that device for a while, but it is hard for someone who see it for the first time. I tried to explain this simple as much as I can. I hope I helped.
Please don't send me more mails. My mail is full. I can not read it all.
NickZ
  v8karlo:   Thanks for your contribution.  Even though your circuit may not produce any extra energy, it may allow the circuit connected up that way, to run longer. Of course, this would need to be tested by some of us here. So, it's good that you are here with us, to give us a helping hand with all this.
   My father and his parents were also from Zagreb, from the old Yugoslavia. I was born in Venezuela, so I am a South American Croat. I highly believe in Tesla, and his ideas on free energy.  Unfortunately, the free energy ideas, and his inventions have been hidden from us, to a great degree.    Can you explain why you are so scared. Perhaps that can help us to understand your concerns. And also, why did you stop working on the device that you have shown, after so many years of working to achieve the results that you have obtained. Also, do you still have the device assembled and working, or not.  Sorry for all the questions.    Thanks again,
                        Nick Zec
AlienGrey
