0 Members and 165 Guests are viewing this topic.
mkjekyll
In Teslas system he concentrated on the B field for his wireless.  If one will notice his later systems are always inductively matched to the ground then antenna wise  a top load to capacitively couple to the air with a spherical cap.  Modern RF we have abandoned the idea of ground match coupling beyond a mismatched wire, well aside from sub communication.  Purturbing the scalar earth magnetic field and taking advantage of this on the receiving end works wonders.
Look at the Magnifying Transmitter patent and one can determine Dr Tesla was using 1/4 wave resonator for about 1mhz although the calculations are not quite accurate as the earth has a diff speed of propogation to free air.
Modulating RF as PM or FM produces the longitudinal factor which with dual sideband can deliver about 16/1 info over carrier freq. as with 4g
AlienGrey
Quote from: Void on July 02, 2018, 05:00:22 PM
The voltage would have to be very high. Also, we are not likely really talking about 1000pF,
as only certain wires or coils had high voltage on them, The capacitance to earth from
high voltage wires or coils was probably a fair bit less I would think. :) Akula showed in that
demo I mentioned that he could light some bulbs as well as self run without an earth ground wire connected.
If it was legit, at any rate it seems something way out of the ordinary was occurring, whatever it may be. :)
I think we should be able to at least agree on that.
Prentice seems to have taken a bit different approach back in 1923, but given the general similarities to Kapanadze's setup
it may possibly work on the same mysterious principle (if they really work).
Sure the Earth makes a big difference but what about the wingdings and resonance 1/4 wave or less what do we know
about the wingdings ?
( the program keeps altering my spelling sorry about that)
AG
Void
Quote from: AlienGrey on July 02, 2018, 06:51:47 PM
AG
I personally don't know what exactly Kapanadze was doing with his special coil.
His coil assembly used in his 2004 demo was similar to the one used in his green box demo,
or it was the same one, but I don't know what is known about how it was wound, beyond people guessing at it.
Jean-Louis Naudin thought he had figured it out with his 'kapagen' experiments, but when he eventually measured the
input and output power with a suitable method it had a COP < 1. It seems whatever info Naudin got about that
setup was either wrong in one or more ways, or he was still missing something else very important from the setup.
Kapandze's 2004 setup used less than 100 Watts at the input. Naudin's Kapagen used a lot higher input power
and had COP < 1.
Something related to consider.
A quarter wave resonant antenna or quarter wave resonant tesla coil requires a ground to
to work to its max efficiency, but a half wave resonant antenna does not require a ground or ground radials.
A quarter wave antenna has much less losses if you use many radials laid on or near the ground for the ground return
because the actual ground is typically quite *lossy* to radio frequencies. If the ground is lossy (has a significant resistance
at radio frequencies) then why did Prentice and Kapanadze get COP > 1 results when connecting to an earth ground point?
Again, for me it points to very possibly something else going on than what we typically see with radio antennas,
and what we might expect with conventional analysis. The ground is supposed to be lossy at radio frequencies, and at
lower frequencies and to DC as well.
If half wave antennas do not require an earth ground or ground radials to work to max efficiency,
then if Kapanadze wound a half wave resonant coil would he no longer need a ground connection?
I don't know, and I don't expect anyone to actually have an answer to that except maybe Kapanadze himself. :D
mkjekyll
AlienGrey
