Belfior
Quote from: vasik041 on December 30, 2018, 07:34:19 AM
There is only one small issue here. Power on L1 is NOT power consumed from power source. Current is not power.
Yes well L1 is still connected to the grid. With an AC grid it does not matter, which way you plug your device into it. It is push&pull and not from plus to minus. This means the voltage has to be there to light the L1 bulb AND the current in L2 seems to be bigger.
I think what you are saying is that maybe the same current goes trough L1, but there is very little voltage?
V8Karlo,which savings or circuit work C.O. P.  should be ex(s)pected ?
At first a great work which gives partial explanation these methods related :
series connection
  https://patents.google.com/patent/WO2004100349A1/en
Voltage step down transformer
  https://patents.google.com/patent/WO2016070292A4/un
load controler
https://patents.google.com/patent/US5130608A/en
                              !! WOW!!
! - effect " Example 1" saving results related
And about dotation/ donation let me see
Sincerely and good entrance in 2019 and success
OCWL
p.s.: in search for the cheapest " zero energy" infrared heat system
https://patents.google.com/patent/GB2203529A/en   + most efficient energy drive !?"ONLY" 15° C ambiental room temperature ?
In the 70' 13° C has been the average indoor ambiental temperature in the U.K. !
vasik041
Quote from: Belfior on December 30, 2018, 07:41:10 AM
Power from source != power on lamp
v8karlo
Quote from: Hoppy on December 30, 2018, 07:51:42 AM
Yes: the message is: brush up on basic electrical principles to avoid getting mislead!
It uses simple existing principles. It does not violate any of the laws. It is made to be simple.
If I used 100 components in there, nobody will be able to understand. It is stripped to minimum so you can understand it.
v8karlo
Build CZero. Start from there. You all have voltmeters.
For a start you don't need anything else.
At the end it is project which can be made in an hour?
Why talk to much?
