IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
Hi tinu,
You petrify me again, my friend! As if you are a highly-qualified expert in electrochemistry as well as in theoretical and applied mechanics too! You are genius! :D
(Please don't be angry again -- I am only joking! :D)
Looking forward to your calculations related to Fc and d.
Regards,
George
George1
Hi guys,
Let us focus again on the zigzag design as described in the first post of this topic.
1) What will happen if:
a) the mass of the blue component is SMALLER than the mass of the black component;
b) the mass of the blue component is EQUAL to the mass of the black component;
c) the mass of the blue component is BIGGER than the mass of the black component.
2) And one modification of the main concept.
Let us assume that the black component is fixed motionless somewhere to some obstacle and is not able to move. In this case it is evident that after entering the zigzag channel section the blue component will decelerate. What will be the value of this deceleration d and how it will depend on the number of the zigzags? After how many zigzags for example the velocity of the blue component will be 3/4 its initial velocity Vo? Or, let's say, 1/2?
And one more question. It is evident that if the blue component enters the zigzag channel section, then the black component exerts force Fc on the obstacle, which does not allow the black component's linear motion. It is evident that the direction of Fc coincides with the direction of Vo. What will be the mean value of Fc for example? Or its maximum and minimum?
So can somebody calculate the values of the deceleration d and of the force Fc for all of us in this forum? It is evident that both d and Fc are bigger than zero ( d > 0 and Fc > 0), but it will be a nice job if some formulas are derived.
(Note. Friction is negligible and the shape of the zigzag channel could be for example an ordinary standard sinusoid. (Or any other curve, if more convenient.))
Looking forward to your answers.
George
George1
Hi tinu,
Waiting for your calculations related to the zigzag system.
Regards,
George
George1
Hi guys,
Please have a look again at the first post of ours in this topic. Let us make the following comparison. (We will repeat some parts of our previous posts.)
1) Please have a look at Fig. 4, Fig. 5, Fig. 5A and Fig. 6.
1A) THERE IS NO FRICTION. (Modern technologies allow to reduce practically as much as you want the experimental error, related to friction.)
1B) Let us assume that the black component is fixed motionless somewhere to some obstacle and is not able to move. In this case it is evident that after entering the zigzag channel section the blue component will decelerate. And it is also evident that the deceleration d (its absolute value and its mean value) will be bigger than zero, that is, d > 0.
1C) It is evident that if the blue component enters the zigzag channel section, then the black component exerts force Fc on the obstacle, which does not allow the black component's linear motion. It is evident that the direction of Fc coincides with the direction of Vo. It is also evident that the force Fc (its absolute value and its mean value) is bigger than zero, that is, Fc > 0.
2) Please have a look at Fig. 1, Fig. 2, Fig. 2A and Fig. 3.
2A) THERE IS FRICTION in the linear channel s-segment section.
2B) Let us assume that the black component is fixed motionless somewhere to some obstacle and is not able to move. In this case it is evident that after entering the linear channel s-segment section the blue component will decelerate. And it is also evident that the deceleration d' (its absolute value and its mean value) will be bigger than zero, that is, d' > 0.
2C) It is evident that if the blue component enters the linear channel s-segment section, then the black component exerts force F'c on the obstacle, which does not allow the black component's linear motion. It is evident that the direction of F'c coincides with the direction of Vo. It is also evident that the force F'c (its absolute value and its mean value) is bigger than zero, that is, F'c > 0.
3) Please compare item 1 with item 2. It is evident that we can always choose a suitable combination of (a) magnitude of force of friction, (b) length of segments s and (c) number and shape of zigzags, for which Fc = F'c, Fc > 0, F'c > 0, d = d', d > 0 and d' > 0. Therefore it is evident that zigzags successfully imitate resistance, which is identical to friction, but without generating heat. And if we use this simple fact in the experiments, described in Figs. 1 - 6, then we can conclude again that:
a) the law of conservation of linear momentum is not correct;
b) the law of conservation of mechanical energy is not correct;
c) both the law of conservation of linear momentum and the law of conservation of mechanical energy are not correct simultaneously.
Let us stress upon the fact that IN GENERAL both the law of conservation of mechanical energy and the law of conservation of linear momentum are absolutely true and correct. There is no doubt about this. But any rule/law has its exceptions and there is nothing special, disturbing and tragic in this fact.
Looking forward to your answer.
Regards,
George
George1
