IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
To lancaIV.
Very, very interesting! Really need some time to consider everything carefully and to understand it thoroughly.
basic literature :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19850314&CC=DE&NR=3330899A1&KC=A1#
The invention is based on the knowledge that there is an analogy between electrical engineering and fluid engineering. [0013]
This consists in the fact that an electromagnetic field around an arbitrarily bent wire-shaped conductor and a flow field around an arbitrarily shaped vortex thread are described by the same law, Biot-Savart's law. The quantities "increase in magnetic field strength" and "increase in speed" therefore correspond to one another. Since magnetic field strength can be concentrated by winding a current-carrying conductor into a coil, an increase in speed can also be achieved in fluid technology by winding a vortex thread into a coil. If you arrange several whibs rotating in the same direction so that their axes lie on a circle, they will rotate around the center of the circle as a result of mutual induction. The induction increases with the number of vortices. The winding speed increases and the wedged threads approach the shape of closely spaced ring vortices. The velocity field that these ring vortices induce in their interior creates the desired concentration effect.
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/F%25C3%25A9lix_Savart
        sonic engineering,also
https://en.wikipedia.org/wiki/George_Constantinescu
https://en.wikipedia.org/wiki/George_Constantinescu#/media/File:Constantinesco_Car.jpg
                                 5 hp ic engine
                             to ? KW electric motor !?
calculation I :
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fripower-elektrofahrzeuge.de%2Felektroauto-umbau-kosten%2F
A 30 kW electric motor can achieve a torque of 170 Nm, which roughly corresponds to a gasoline engine with a displacement of 2,000 cm³ and 95 kW (129 PS).
                                                 ( 5 hp / 129 hp ) x 30 KW = 1,162 KW nominal electric motor
calculation II :
Re: car energy consume improvements  « Reply #2 on: July 03, 2016, 03:37:14 PM »
from the austinev.org page:ic-engine:136HP=100KW ~12,5 KW electro motor
www.austinev.org/evalbum/motor
"The peak hp of an electric motor is usually 8 to 10 times its  continuous rating."
                                    ( 5 hp / 136 hp) x 12,5 KW = 0,46 KW ::) nominal electric motor
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=toribio+bellocq&IN=&CPC=&IC=&Submit=Search
https://worldwide.espacenet.com/publicationDetails/description?CC=GB&NR=324598A&KC=A&FT=D&ND=3&date=19300130&DB=EPODOC&locale=en_EP#
In general, liquids are regarded as incompressible: but all are sufficiently compressible and elastic to give rise to the following phenomena, and to transform the liquid into a kind of spring Owing to this compressibility and elasticity, the laws of acoustics in sonorous pipes are applicable to them, as are also the most recent laws of electricity as applied to wireless aerials, the suction pipe being comparable with a sonorous pipe Vibraf Price 1/-1 324,598 tion occurs in the pipe, producing a pressure wave which travels the whole length 55 of the pipe.
https://worldwide.espacenet.com/publicationDetails/description?CC=GB&NR=352453A&KC=A&FT=D&ND=3&date=19310707&DB=EPODOC&locale=en_EP
An action, analogous to induction inl electrotechnics, which should be called inertia, can be attained with the device g0 according to the invention by reductions of the cross-section of the liquid pipeline. An additional space. connected with the liquid pipe-line, and filled with liquid, has an effect which is analogous to 95 capacity in electrotechnies. With the device according to the invention, the media working as inertia, holding-capacity, and leakage, can be provided inl any desired number, and may be fornied 1j( so that they let through or pr oduce either only vibrations of low frequency or -only those of higher frequency, or also on the other hand only vibrations whose frequency lies between two predetermined ios values, and alter or hold up the other vibrations. For thle arraingement of these media, working as inertia, holdingcapacity (volume), and leakage, the same laws hold as in electrotechnics for the iijl arrangement of filters working 'as induction, capacity, etc. It is comparatively simple to arrange that the media employed according to the invention have only a small margin of error in relation ii5 to the desired cut-off frequency.
https://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=102012002418A1&KC=A1&FT=D&ND=3&date=20130814&DB=EPODOC&locale=en_EP#
Figure 3 instead "passive windturbine" a "permanent active ..... "  ::)
nix85
Quote from: George1 on February 02, 2021, 07:59:43 AM
To nix85.
Some instructional pictures and/or videos related to this two-swords experiment? May be there is some secret here? Маy be it is better if we аsk a professional athlete to carry out this rotational experiment?
No pictures or videos, those are top secret. Yes, professional athlete is needed to perform this delicate experiment, he must wear a cooking pot on his head while doing it and chair must be precisely aligned with true north (not magnetic north) for success.
NdaClouDzzz
George1
To nix85.
Ok, let us assume that the experiment works. What will be the next step?
