IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
nix85
either i really am
"absolute ignoramus and an absolute amateur in the field
of theoretical and applied mechanics"
or you are a clown with internet access you should not have been given
something tells me the latter is the case
George1
The link below describes a few simple experiments, which break the law of conservation of mechanical energy and the law of conservation of linear momentum. You can easily carry out these simple experiments in your garage as many times as you want.
And here is the link:
https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe
IMPORTANT NOTE 1. It is highly recommendable that the above mentioned experiments  are evaluated and realized by a highly qualified expert (Ph.D.) in theoretical and applied mechanics.  Otherwise nothing will come of it (most probably).
IMPORTANT NOTE 2. The key question in the above mentioned experiments is how to reduce standard friction (where necessary) to a certain minimum limit, beyond which the experimental error (due to friction) is small enough and can be neglected. The answer is simple. You can use for example permanent magnet slides as shown in the link https://www.youtube.com/watch?v=NoW0A8hYs5A . (Permanent magnet slides reduce friction practically to zero and the measuring devices do not register any force of friction.) Aternatively you can use hundreds of other methods for reducing of friction (as much as necessary) as modern technologies allow this feat. We live in 21st century after all.
Looking forward to your comments after repeating the above mentioned simple experiments.
nix85
to counterweight the misinformation, i'll just repeat once again
any unbalanced weight that rotates convert centrifugal force into
linear acceleration. simple as that
George1
To nix85.
I do not argue about this. You are right. Accepted.
George1
