IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
The link below describes a few simple experiments, which break the law of conservation of mechanical energy and the law of conservation of linear momentum. You can easily carry out these simple experiments in your garage as many times as you want.
And here is the link:
https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe
IMPORTANT NOTE 1. It is highly recommendable that the above mentioned experiments  are evaluated and realized by a highly qualified expert (Ph.D.) in theoretical and applied mechanics.  Otherwise nothing will come of it (most probably).
IMPORTANT NOTE 2. The key question in the above mentioned experiments is how to reduce standard friction (where necessary) to a certain minimum limit, beyond which the experimental error (due to friction) is small enough and can be neglected. The answer is simple. You can use for example permanent magnet slides as shown in the link https://www.youtube.com/watch?v=NoW0A8hYs5A . (Permanent magnet slides reduce friction practically to zero and the measuring devices do not register any force of friction.) Aternatively you can use hundreds of other methods for reducing of friction (as much as necessary) as modern technologies allow this feat. We live in 21st century after all.
DEEP SILENCE AGAIN?
WHAT HAPPENS HERE IN THIS FORUM?
WHERE IS THE PASSION FOR NEW TECHNOLOGIES?
WHERE IS THE "TESLA" PIONEER SPIRIT AND ENTHUSIASM?
LOOKING FORWARD TO YOUR ANSWER.
George1
Still no comments related to the link https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe  ?
Isn't there at least one brave person here in this forum who dares to say that the law of conservation of mechanical energy and the law of conservation of linear momentum are not correct?
George1
To Jerry Volland.
Hi Jerry,
Thank you for your post.
1) Well, the link https://www.youtube.com/watch?v=xX14NK8GrDY&ab_channel=PeterAxe  describes clearly a simple experiment, which unambiguously violates the law of conservation of linear momentum and the law of conservation of mechanical energy. In one word, you simply measure heights, velocities and masses and after that you simply calculate (this is the method) the related potential and kinetic energies, and the related linear momentums, respectively. And after that you simply compare the numerical results.
2) The violation of the law of conservation of linear momentum directly leads to a possibility of designing and manufacturing of a simple reactionless drive machine. (Please ask an expert (Ph.D.) in theoretical and applied mechanics to consider carefully and thoroughly the link above. And after that ask him/her to explain to you the essence of our experimental approach.)
Looking forward to your answer.
Regards,
nix85
as long as unbalanced mass oscillates within 180 degrees or less
system accelerates linearly, that is all
https://youtu.be/JGLrVgYdpRw?t=340
nix85
technically, if you accelerate the system by any means totally within the system
you are violating conservation of momentum and energy
