Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
aether22
Look at this image drawn of Henry Moray's device, there are 2 metal bars, one labeled Lead, the other Silver (hard to make out, but it's Silver).
So that's a funny "coincidence" no?
The person muses over what purpose 2 sizable parallel bars of metal could have, despite it somewhat resembling the burred bars of Louis Rota!
Also if this diagram is right (why wouldn't it be?  it was some witnesses attempt to understand Moray's device after witnessing it) and if it is used as I propose (what other use could 2 parallel bars of metal like that POSSIBLY have?) then this suggests that indeed, as per ROTA and Stubblefild, a fair mass can or should be employed of these metals, he might have used lead solider, but a huge mass of lead was more suited!
So this now encompasses all the early inventors!
Belfior
In "Evolution of Matter" https://www.amazon.com/Evolution-Matter-Classic-Reprint/dp/1332011764
le Bon comes to the conclusion, that electricity is effect cause by radioactive dissimilation of matter and that everything is radioactive. Something like steel radiates very slowly compared to uranium, but use a catalyst like shine a light on a metal plate and it will start radiating. He also found out that by combining materials you can make elements react violently even if they seem stable otherwise. This made him think that electric effect could be also gotten without equal power in.
He also says radiation will render air conductive, so there are ions there. What if you use a spark gap covered with bismuth or cover copper coils with molten bismuth?
Belfior
a good place to start investigating Moray so you don't start from scratch
http://www.linux-host.org/energy/smoreland.html
Gustave le Bonn seems to be on his reading list too...
aether22
Quote from: Belfior on August 13, 2018, 05:33:52 AM
I have Bismuth, I would be tempted to add it as a block as Moray did in that example.
At any rate, whatever criticisms anyone might have about Moray and radio transmitters, it is irrelevant when one considered that Moray's other achievements, all very soundly in the realm of aetheric sciences.
He also used radionic like tuning to pickup conversations.
He is not dealing with regular energy, Steven Marks too might have cheated by being near megavolt lines, and others might have found similar such advantages, there is a speculation about the Kipper motor and Microwaves...
And Stifler I believe had some big electrical gear near him.
But, all of that is not about tapping actual conventional energy, but rather the aetheric side of that energy, much like John Hutchisons effects!
Apparently Bedini had one design work great near a radio transmitter.
I have a friend who gets success that I am pretty sure is largely related to his ham radio transmitter!
The point is that these things add a component to the aetheric energy background, they add a component...
Combine with ions in the air, also maybe ozone, this makes for an environment that is very suitable for this kind of work!
It excites the air, the environment around the experiment and reduces what the experiment needs to provide to get results.
As is the use of Radium, which again John Hutchison used a radioactive sample.
So radium, ions, ozone, maybe HV, RF and other electrical emissions...  Multi metals, Loads creating vibration (Piezo, Keely/Davidson/Wootan), light (Carbon arc lamp), motor...  Ground, other aetheric principles... = Success.
In other words this stuff needs a wide bandwidth of different energy signatures before it begins to have real physical effects, it also needs to cycle energy between components as this processes the aetheric and the electrical energies together.
But, aetherically/radionically, everything does indeed radiate, but that is not hard particle radiation.
nelsonrochaa
Quote from: aether22 on August 13, 2018, 06:25:26 AM
Hi , before you start play with bismut and high voltage take a radiation detector near you for your own protection.
The transmutation of bismut  could be very  danger to your health .  Is only a advice :)
Cumpliments
Nelson Rocha
