Self-Powered Generator - Inventor From South Africa
Started by SkyWatcher123, August 11, 2018, 01:18:43 AM
SkyWatcher123
Hi all, have been wanting to experiment more with mechanical devices, like I used to in the past.
I think the magnets rotating can be of benefit.
So, I am going to work with the ideas shared by Patrick Kelly, based on the anonymous inventor from South Africa.
What i have so far, is what I have on hand, will need to wind more coils though.
Starting out with the 12 strand, 24awg. magnet wire coil, not twisted with ferrite tube core.
Rotor has 1" diameter by 1/8" thick magnet on each end, total of 4 neo magnets.I am using a 400 size rc brushless outboard motor as the bearing and support structure for the rotor.
I removed the small neo magnets from the outboard casing of the motor, using a lighter to soften the glue holding the magnets, so now the rotor can spin freely.
Here is picture of what I have built so far, need to wire up the bedini type circuit for motor pulse action and other components.
https://www.youtube.com/watch?v=3Q6NA5N6ioU
http://www.free-energy-info.com/Rotary.pdf
peace love light
SkyWatcher123
Hi all, I had to modify the setup a bit, because the motor i was using for the rotor support structure and bearing, the bearings were bad.
It is now smooth and quiet and runs well.Using a 3 cell parallel pack of lithium ion cells for 4 volts input.
Have another identical battery pack as the charge battery.Using the basic circuit diagram shown in the pdf.
Still testing with just the 12 strand coil and ferrite core, will be adding more separate, single strand coils later, will have 4 total.peace love light  :)
SkyWatcher123
Hi all, the testing is looking very interesting so far.
I switched to 12 volt tractor batteries for testing and the results so far are looking promising.
The other smaller, longer coil on the right in the setup, is not being used at the moment, it is 7 strand 24awg. coil, though it does help balance out the rotor from vibrations.
So far, the input side is actually gaining a little voltage after every test run and the charge side charges very well.
The batteries are meant to swap positions.Questions or comments welcome, shall continue testing.peace love light :)
forest
You can use old hard drive. It has excellent bearings, though I don't know how to safely glue magnets to the hdd plate
aldex
I registered on the site to follow up on your work. I've been struggling with energizers for some time but so far no really satisfying results. I have a certain difficulty in this project that when other collector coils are placed the rotor slows down a lot.
